Moser m9
Moser m9
Housing and 40 spline star flange gun drilled axel, 5/8 studs. This fit stock sups mustang, it has back brace coil over bracket set up base on team z coil over bar mount. Also has solid bushings for upper control arms. 50" flange to flange.
$750.00 912-387-5260
chuck- Posts : 414
Re: Moser m9
I also have a moser center, 35 spline pinion, pro 389 gear, 40 spline spool. I'll let it go with the housing for $800.00. That will be $1550.00 for both.
chuck- Posts : 414
Re: Moser m9
Hey Chuck, im ready. I got the money. When you get off and get home I should be finished out back and can come pick it up.
tconnection- Posts : 866
» Moser Axles F/S...
» MOSER 33 and 31 spline spools
» 69 Mustang 31 spline moser
» 35 spline Moser truck axles
» Moser axles and rotors
