Nice Flow Numbers on These
John I.
yellowhorse7
Nice Flow Numbers on These Empty Nice Flow Numbers on These
Post  supervel45 January 23rd 2014, 3:17 am
http://www.mbellc.com/index.php/component/virtuemart/?page=shop.product_details&flypage=flypage.tpl&product_id=43
Nice Flow Numbers on These Empty Re: Nice Flow Numbers on These
Post  yellowhorse7 January 23rd 2014, 9:12 am
Couple of 275 cars from the East Coast running those I believe
yellowhorse7
yellowhorse7
Post  supervel45 January 23rd 2014, 7:44 pm
yellowhorse7 wrote:Couple of 275 cars from the East Coast running those I believe
How are they doing?
Post  yellowhorse7 January 23rd 2014, 7:59 pm
        How are they doing?
Not bad from what I have seen. Mostly nitrous guys. But there is so much under the valve covers and in the combustion chamber who knows exactly what has been done.
yellowhorse7
yellowhorse7
Post  supervel45 January 24th 2014, 12:37 am
The flow numbers look real good, but they sure are pricey. They are claimed to be an A head, did not want to throw them into the other heated SCJ-P51 firestorm. I just never have seen them mentioned around here before. Their C-head looks about the same on their webpage, as for as flow numbers also. Anyway 522cfm don't seem to shabby, if it is true.
Post  John I. January 24th 2014, 12:50 am
I know next to nothing about cylinder head flow, so maybe someone can tell me why such a small exhaust valve compared to the intake? 344cfm seems pretty good for that size of valve.
John I.
Post  supervel45 January 24th 2014, 1:03 am
John I. wrote:I know next to nothing about cylinder head flow, so maybe someone can tell me why such a small exhaust valve compared to the intake?  344cfm seems pretty good for that size of valve.
344cfm flow is good on any size valve. Kidding aside 1.83" is not real big. I did not see any lift number's, so I assume it is at .800" lift? Maybe it's the port shape? Good question though.
Post  yellowhorse7 January 24th 2014, 9:40 am
supervel45 wrote:The flow numbers look real good, but they sure are pricey. They are claimed to be an A head, did not want to throw them into the other heated SCJ-P51 firestorm. I just never have seen them mentioned around here before. Their C-head looks about the same on their webpage, as for as flow numbers also. Anyway 522cfm don't seem to shabby, if it is true.
Here's what I DO know about A Heads in some of the FAST Radial tire cars........this says nothing about the product that you originally posted about. They look like a great piece.
ALOT of them are not A heads anymore, at least an A Head in it's complete OEM architecture. They are essentially C/Thor heads in disguise. I'll leave it at that....
yellowhorse7
yellowhorse7
Post  supervel45 January 24th 2014, 1:42 pm
I have a feeling you are right YellowHorse. Something definetly sounds off about the ones I posted.
Post  bruno January 24th 2014, 3:54 pm
when I talked to him about those cylinders heads several years ago they the had the skin of the a460 but everything else was changed , most of the flow was gained from the change in angles  Wink
http://WWW.CKRME.COM
Post  supervel45 January 24th 2014, 6:14 pm
bruno wrote:when I talked to him about those cylinders heads several years ago they the had the skin of the a460 but everything else was changed , most of the flow was gained from the change in angles  Wink
 What did they quote you on complete heads? I did not feel like plugging in all the options in their quote form, but it looks like 7-10k would ring up pretty quickly? Also they are on 4.5" bores so you need a aftermarket block. Their C-heads are 4.3' bore, not sure if you can use a stock block with them, not that you would want to at this level anyway? Whats up with the body building chick avatar? She looks good, but its cold now, need a tad fat not to freeze. Suspect
Post  Frank Merkl January 24th 2014, 10:15 pm
C460 would never fit a 4.300 bore , 4.500 is tight on a 2.400 intake valve ,Ford recommended 4.550 min bore
Post  supervel45 January 24th 2014, 10:54 pm
Frank Merkl wrote:C460 would never fit a 4.300 bore , 4.500 is tight on a 2.400 intake valve ,Ford recommended 4.550 min bore
I was going off of their website. If you go to the link, at the right side and click on the C-Head it is on the spec. sheet. It could be a misprint, but it is there.
Post  bruno January 25th 2014, 12:16 am
the invoice was around 12k which included the matching manifold
Post  supervel45 January 25th 2014, 12:33 am
ChaChing$$$$$WOW Gota Pay to Play with the Big Boys!
Post  Larry T January 25th 2014, 12:54 am
when did the coomers change over to fords?last I seen them pulling they were in chevy's......
Larry T
Larry T
Post  supervel45 January 25th 2014, 1:49 am
http://www.zoominfo.com/p/Mitchell-Coomer/1706978330 This is dated 2011, not sure exactly when?
Post  cool40 January 25th 2014, 2:05 am
supervel45 wrote:http://www.zoominfo.com/p/Mitchell-Coomer/1706978330               This is dated 2011, not sure exactly when?
he builds for some other pullers. his stuff is chevy powered.
Post  supervel45 January 25th 2014, 2:52 am
http://www.pulloff.com/phorum/read.php?2,115810,115866 This is from 2012. 1950 Chevy "Top Gun" I cannot find any other links. Nota, and I looked for awhile.
Post  cool40 January 25th 2014, 10:41 am
midsouth pullers on YouTube has a bunch of his yeller and black truck.my neighbors pull against him a lot, the have a chevy too.lol....its a fun sport I have thought about lately.
Post  supervel45 January 26th 2014, 12:14 am
Has anyone ever seen these heads in person at the race track? I quess for the price, there are not alot of them floating around?
