Better Oiling for the 460
+9
racinghabbit
strokedmyford
LivermoreDave
powerstrokeace
dragsterdick
13 posters
Page 1 of 2
Page 1 of 2 • 1, 2
I am told by Blue Thunder that they have a better oil filter system and use a bigger filter to get oil thru the bearings. Does anybody know about it or use it?
dragsterdick- Posts : 54
Re: Better Oiling for the 460
I've never had an issue using a jomar or fl1hp filter.
tell me how you can provide more oil through the same size oil channels in the block?
Ace
Ace
powerstrokeace- Posts : 1496
Without details and generally speaking, increase volume.
Dave.
Dave.
LivermoreDave- Posts : 972
460 Oiling
Dave and Ace, I don't know how you can either, but he was telling me that the way he bolts the filter on and a truck diesel filter gives better oiling to the rear of the motor? Just wondered if anybody else knows anything ?
When I do my block mods on a stock block,I drill out the passage from pump to filter to I think its 9/16
bbf-falcon wrote:When I do my block mods on a stock block,I drill out the passage from pump to filter to I think its 9/16
Rick I go 5/8 but you are right any bigger is a plus if you decide to do this do it in steps not just get a 9/16 of so bit and drill away I also drill out the passage to the main galley also...
the Coug- Posts : 3055
dragsterdick wrote:Dave and Ace, I don't know how you can either, but he was telling me that the way he bolts the filter on and a truck diesel filter gives better oiling to the rear of the motor? Just wondered if anybody else knows anything ?
I'm not educated with the aftermarket's BBF (385 series) architecture. The Ford OEM version is very similar to the Ford 335 series. A simple yet effective approach to provide additional oil to the rear of the Ford OEM 385 series engine is to add an oil line from the front driver's side oil pressure orifice to the top rear oil pressure orifice. Also, higher filtration oil filters or compounding oil filters will create a restriction in flow of the oil. If an extra amount of filtration is required this may be an effective means to filter the oil, otherwise less restrictive oil filters may offer an advantage as to the oil's ability to traverse through the engine.
Just my slick opinion,
Dave.
I stumbled across this the other day http://www.enemyracing.com/oilsys.html
strokedmyford- Posts : 126
That's appears to be very similar to the Ford 335 series P/S and S/S preparation applied years ago.
Dave.
Dave.
I've never noticed a problem with the stock system as long as the engine is assembled correctly and the clearances are correct. Seems like a lot of trouble for little gain to me.
about 2 years ago i found pictures and a detailed info on how do smooth out the passages and open up the hole by the oil filter and radius the turn...
I wasn't very happy with the end result.. I put a jon kaase oil pump in it and clearanced the bearings for 10w30 vr1... and at 900 rpms i had less than 5 lbs of oil pressure......
Maybe i made a mistake , or opening it up that much was too much....
My experience, not messing with it works just fine... i've built couple 302, 351w, 460, pontiac 455, 500 caddy... and they all still run with great oil pressure....
racinghabbit- Posts : 575
Hey Coug, I'm confused--why are you directing engine oil to the kitchen?the Coug wrote:...I also drill out the passage to the main galley...
That trick originated with the 335 Series. And although the 335 oiling system is indeed similar to the 385 oiling system (virtually identical but with one very significant difference), I am thoroughly (and I mean thoroughly) convinced that adding the typically fashioned 335 external line to the 385 Series does more harm than good. And when I say that I don't mean "it can't hurt anything," I really mean, "does more harm than good."LivermoreDave wrote:I'm not educated with the aftermarket's BBF (385 series) architecture. The Ford OEM version is very similar to the Ford 335 series. A simple yet effective approach to provide additional oil to the rear of the Ford OEM 385 series engine is to add an oil line from the front driver's side oil pressure orifice to the top rear oil pressure orifice.
I know passenger car blocks (past and current) with OEM oiling systems that support thousands of horsepower; please remind me again what the benefit is with this "frankensteined" primary mains oiling system?strokedmyford wrote:I stumbled across this the other day http://www.enemyracing.com/oilsys.html
You have a lot to learn about these engines, grasshopper...racinghabbit wrote:about 2 years ago i found pictures and a detailed info on how do smooth out the passages and open up the hole by the oil filter and radius the turn...
Paul Kane wrote:LivermoreDave wrote:I'm not educated with the aftermarket's BBF (385 series) architecture. The Ford OEM version is very similar to the Ford 335 series. A simple yet effective approach to provide additional oil to the rear of the Ford OEM 385 series engine is to add an oil line from the front driver's side oil pressure orifice to the top rear oil pressure orifice.
Mr. Webster's definition of harm. Hurt; injury; damage. To do harm to.
Coug, can you clarify Paul's response to my post, I can't!
Dave.
LivermoreDave wrote: Coug, can you clarify Paul's response to my post, I can't!
Dave.
Nope Dave you will have to get one of the dreamers to clarify it for you, they say they are the one with all the knowledge or the God Squad
[quote="racinghabbit"]about 2 years ago i found pictures and a detailed info on how do smooth out the passages and open up the hole by the oil filter and radius the turn...
I've modified quite a few of these blocks using PK's info and have not noticed any loss of pressure, so I can't see why opening up the passages would'nt help.
I followed everything to a t... motor ran strong... and i did not have any bearing problems ...
Just saying its freaked me out... haveing low oil pressure and my oil pressure switch was a 5lbs so sometimes staging it would die out..
Yes , i have a lot to learn... i'm all eye's and ears...
Weird shit happens sometimes.
bbf-falcon wrote:Weird shit happens sometimes.
That's the way I remember while watching Up in Smoke! ... ...
Dave - Like most I have a lot to learn too and I am always trying to learn more. Having said that I have a similar external line to the back of my 382 block tee'd into a 3 quart accumulator and have been very satisfied with the results. Provides me opportunity to pre-oil the engine before starting it (big plus!) and oil pressure at the big end has been much better.
Rich Osmond- Posts : 217
385 block....
I did the mods on PK's website to my old mud truck moter and saw no change in oil pressure(35-45 psi hot) but my bearings looked better at the end of the season at which time I had lifter bore bushings installed to correct the lifter angles and to reduce the lifter clearance as my machinist thought it was a little to much. After this modification oil pressure increased(60-70 psi hot) and bearings looked like new after a full season of racing.
lghting94- Posts : 762
Page 1 of 2 • 1, 2
Page 1 of 2
