oiling questions
oiling questions
stock cast iron block.
is the rear oil passage the most accurate place to run the oil pressure gauge from? do I just plug the front passage ?
where should I plum the accumulator to? an oil filter adapter?
Larry Williams- Posts : 884
Re: oiling questions
For taking an oil pressure reading either the front or rear port will work, but it's preferred to take it from the rear whenever possible since the pump/oil is fed to the block up front and the pressure reading would then be farthest from the pump and after all bleed-off points.
I have seen most accumulators plumbed at the front of the block. I feel that they might be better positioned at the rear, however when plumbing at the rear the 5/16" oil pressure port passage that reaches down to the passenger-side lifter gallery should first be enlarged to 3/8", and the 1/4-NPT thread also enlarged to 3/8-NPT. Lastly, unless you are installing the accumulator specifically for avoiding dry start-ups, I suggest you first determine why your engine is losing oil pressure in the first place and try to eliminate (or at least minimize) the culprit beforehand.
thanks for the quick reply paulPaul Kane wrote:For taking an oil pressure reading either the front or rear port will work, but it's preferred to take it from the rear whenever possible since the pump/oil is fed to the block up front and the pressure reading would then be farthest from the pump and after all bleed-off points.
this is a new never run install, so no oil problems yet. I have the accumulator from my other engine just as a safety item. its too late to enlarge the oil pressure port. I an guessing the only option I have is a remote oil filter system I can plumb into for the accumulator. Your thoughts?
Most people have the remote filter system plumbed at the filter pad, and have the accumulator plumbed at the front pressure port...if you really feel you need it even though you have not yet had oil pressure loss issues.Larry Williams wrote:...this is a new never run install, so no oil problems yet. I have the accumulator from my other engine just as a safety item. its too late to enlarge the oil pressure port. I an guessing the only option I have is a remote oil filter system I can plumb into for the accumulator. Your thoughts?
Why is it "too late" to enlarge the rear pressure port?
engine is assembled and in car.........
kim- Posts : 700
I may have overcomplicated it when I ran mine.. Not an uncommon occurrence by the way...
I placed a tee and a check valve in the discharge line from my remote filter and plumbed my accusump in there. that cured my loss of oil pressure under braking issue I was having with my wet sump canton pan.
The check valve was to stop any oil from flowing backwards through the pump when pressure was low or non existent.
dkp
dkp
bosshoss- BBF CONTRIBUTOR
bosshoss wrote:I may have overcomplicated it when I ran mine.. Not an uncommon occurrence by the way...
dkp
what did you use for a check valve? any pics?
I dont have any pics but I think the valve I used was an Earls 251010.
dkp
dkp
» Better Oiling for the 460
» No Top End Oiling
» oiling system
» 460 oiling question
» Help with a problem on oiling?
» No Top End Oiling
» oiling system
