532 Ford with BT heads
532 Ford with BT heads Empty 532 Ford with BT heads
Post  79Puller January 31st 2014, 8:31 pm
I have a 532 Ford for sale, D1 block, Scat billet 4.30 crank , Oliver Biller 6.8 rods with Diamond pistons, Kaase pump, Canton pan, cloyes timing chain, double roller, Comp Solid roller cam and lifters , lifters are bushed also, alum Blue Thunder " B " heads with the checy exhaust port, Trick Flow " Mafia " intake and top with a Hollet 1050 dom and a MSD dist.and electric water pump, fabbed valve covers etc. ABout a year and half on the motor but everything looks good. Cam was spec'd by and can provide cam specs ( 800 ish lift ) Asking $8500.00 motor was never dyno'd but does run strong to 7500.
79Puller
532 Ford with BT heads Empty Re: 532 Ford with BT heads
Post  79Puller February 7th 2014, 1:14 pm
bump
79Puller
Post  79Puller February 8th 2014, 6:55 pm
SOLD..........pending payment
79Puller
