ford heads
takota1982
ford heads
i have a set of c9ve-a ford heads with roller rockers and comp rods and springs just want to know how much they are worth thanks
takota1982- Posts : 9
Re: ford heads
Tell us a little more info. Do they have big valves, any porting,etc.
ford heads
yes they have large springs the heads came out of my jet boat
ford heads
and they look like they have had some porting work done
ford heads
not yet but will just wanted a ball park price would like to sell them thanks
Re: ford heads
W/O much info, probably $300 jmo
Re: ford heads
I'll agree with Rick on that amount, if you had some flow sheets for them with good #s maybe $500.bbf-falcon wrote:W/O much info, probably $300 jmo
schmitty- Posts : 4538
ford heads
cool thanks i had someone look at them and they said the oval port heads i have are rare and worth 800 hundred a side so i just wanted to see what they are worth
Re: ford heads
takota1982 wrote:cool thanks i had someone look at them and they said the oval port heads i have are rare and worth 800 hundred a side so i just wanted to see what they are worth
The factory style heads are all oval port. Sold my last set for $150. Good luck getting $1600 out of yours...
P.S. "someone" is an idiot imo
Nevs- BBF CONTRIBUTOR
ford heaads
thats what i thought i new ford garbage could not be worth that much
Re: ford heads
Takota, We aren't cutting your heads at all. They are really a decent head if they have some work done to them. And it is true. All of the oem 429/460 style heads are oval port,the bad,better and the best.They don't become rectangle until you get into the Race heads. Sorry man, just answering your
Re: ford heads
takota1982 wrote:thats what i thought i new ford garbage could not be worth that much
I never said they were garbage, simply that they weren't worth what you were told. You need to be pissed at the " someone " who told you they were worth that kind of money. Unless they were the iron SCJ heads and had a ton of work done to them would they be worth anywhere near that figure. It doesn't sound like you are truly a Ford fan from your statement, too bad.
Re: ford heads
stick to your double hump heads then... there worth a fortune
138- Posts : 1593
ford heads
no not at all had yhem on my jet boat and blew a few motors and sold the boat and kept the heads but have no use for them anymore the guy said they were indy heads are you faamiliar with that i have know idea
Re: ford heads
takota1982 wrote:no not at all had yhem on my jet boat and blew a few motors and sold the boat and kept the heads but have no use for them anymore the guy said they were indy heads are you faamiliar with that i have know idea
Id like to meet that guy thats been telling you that garbage. I can tell you w/o a dought he doesn't have a clue about any Ford engines. As far as I know INDY doesn't make any Ford heads, they ARE into the Chrysler engines heavy though.
Re: ford heads
Indy heads are MOPAR stuff..... Now Your really lost. Get some pictures before we go any farther. you need t determin just what you really have to get what there really worth. Its like selling ocean front property in Arizona
Ace
powerstrokeace- Posts : 1496
ford
they have ocean front in arizona i pulled the of the 429 that was in the boat
» Wanted..... Cast iron Blue thunder Ford port heads or CJ heads
» FS: New set of Ford M-6049-SCJA aluminum cylinder heads.. HEADS SOLD, Thx
» 532 Ford with BT heads
» ford hemi heads
» WTB Ford Motorsport A-460 heads
» ford hemi heads
