cam question
mitch
cam question
I've been getting some parts together for a pulling truck engine, It will be a stock stroke, bored .06, single plane intake, headers, big 4150 carb. I got a good deal on a set of big valve, ported D0VE heads and comp roller cam form a forum member. Will this cam work ok for me? I think it was intended for a 4.3 stroke build.
cam specs intake exhaust
gross valve lift .787 .726
duration @.02 tappet lift 303 323
duration @ .05 273 288
lobe lift .455 .420
lobe lift .455 .420
mitch- Posts : 116
Re: cam question
What's the rest of the build? How much compression? Head flow? What trans? Convertor? Gearing?
Re: cam question
It's a pulling truck so converter and gearing aren't applicable. It will need to run a lot of RPM though, at least 7500. The only info I got for head flow is 340 @ .8 lift. I don't know what the compression ratio will be. it can run race gas so maybe about 14:1 it will depend on what I get for pistons.
mitch- Posts : 116
Re: cam question
with a set of 3.00 gears, that cam won't work, unless you have a very- very high % of tq/conv. slipmitch wrote:It's a pulling truck so converter and gearing aren't applicable. It will need to run a lot of RPM though, at least 7500. The only info I got for head flow is 340 @ .8 lift. I don't know what the compression ratio will be. it can run race gas so maybe about 14:1 it will depend on what I get for pistons.
DanH- Posts : 1081
Re: cam question
why do you think I have 3.00 gearsDanH wrote:with a set of 3.00 gears, that cam won't work, unless you have a very- very high % of tq/conv. slip
![confused](https://2img.net/i/fa/i/smiles/confused.png)
The gearing will be more like 27.00:1
just want to know how it will run with that cam.
mitch- Posts : 116
Re: cam question
That cam will work, but your going to have to keep the rpm up because it will drop below the power curve fairly quickly.
There will be less than 1000 rpm between torque peak and hp peak more like 7 to 800.
With some intake work you could get that spread wider and pick up some hp also.
If you haven't bought one yet a mafia intake would help with that cam.
Re: cam question
thanks i was leaning towards the mafia intake
about what rpm would it peak?
mitch- Posts : 116
Re: cam question
^^^ sage advice.IDT-572 wrote:That cam will work, but your going to have to keep the rpm up because it will drop below the power curve fairly quickly.
Re: cam question
What is the lobe separation? Sounds like the cam will do what you're asking, peak torque may be around 6200 give or take and might horse peak around 67-6900 depending on if the heads are good and lobe separation. If the lobe sep is 112 or so it will hold on better. If it is around 108 it will probably never see 7500.
Bret
Bret
Bret Powell- Posts : 133
» P-51 QUESTION
» Custom oil pans???
» n2o question
» C6 Question
» P-51 QUESTION
» n2o question
» C6 Question
