Plates for tunnel ram
I need help with the tune on my 588 ci BB Ford with 2 1050 dominators. What plates do I need and what jets should I use to get about 200 HP? The carbs have 95 jets now, but that sounds rich to me. This is a new install, so any advice would be appreciated. The truck weights 3860 with driver and runs 9:70 @ 132 in 1/4 now.
Bob
Bob
Godzilla- Posts : 92
Re: Plates for tunnel ram
We sell a nice dual dominator kit that sounds exactly what you are asking about. Contact the number in the signature if interested.
whatbumper- Posts : 3024
95 squared times two carbs does sound rich to me but the truck looks to run well from your et. How do your plugs look after a pass? Do they foul often?
Get that thing dialed in correct on the motor with the carb jetting, then mess with the NOS twin plate jetting afterwards. For a total of a 200hp shot, you'd simply jet each plate for a 100 hit. I think a 52N jet will put you about 100hp. Fuel jet ought to be smaller, perhaps by 4 sizes to start which is likely too fat. Read your plugs and tune from there. I'd start with your total at 20 degrees to be safe. I don't know your combo so I'm on the cautious side. Again, watch plugs and tune from there. Oh yea, when testing run better fuel too. Play it real safe until you start getting things sorted and you can see what it wants.
4thHorseman- Posts : 400
What heads, what RPM is peak hp at? Not saying yours needs it but mine is -60CI with two 1095's and needed more jet than what you have, so don't get too concerned with the number just give it what it wants.
Just bring that thing up to Caddo Mills one night and let me know when you're coming and I'll help for free the first time. We will be tuning at Kennedale the 14th at a TOPMA race and at Ennis the 15th for a TeX275 race if you feel like making those hauls.
» Trickflow A460 tunnel ram and c460 adapter plates
» FS: Motor Plates & Mid-plates -- BBF & Hemi
» engine plates (motor) steel and alum
» front and or mid plate
» motor plates
» motor plates
