has this happened to anyone else?
+13
fastford600
chuck stevens
studly
fastfalcon
17 posters
has this happened to anyone else? Empty has this happened to anyone else?
Post  fastfalcon November 5th 2009, 9:45 pm
So I'm at the ford fever classic at MIR, I've made 7 passes all in the 10.30 range, all is good. All of a sudden no oil pressure. Fastforward two weeks later and the motor is on the stand and I find I have actually broken my oil pump into two pieces just below the mounting flange. Has this happened to anyone else? the bearings are all shot and there is one spot on the crank throw that hit the pump before it could get out of the way but all in all everything else looks ok. The pump was a melling HV. Also I want to convert this to a 4 bolt main, any suggestions on brand or other advice? thanks in advance! affraid
fastfalcon
has this happened to anyone else? Empty Re: has this happened to anyone else?
Post  studly November 5th 2009, 9:51 pm
I have had 10 bbf motors and never had that problem have run the melling Hv in all of them, but i have always used red loctite on the bolts that hold the pump because i felt they were heavy and with the strain they are under with the 25w50 oil i run just felt better doing it. sorry to hear that about yours
studly
studly
Post  dfree383 November 5th 2009, 9:52 pm
It's not an uncommon problem, spend the extra $$$ on a Kaase pump, it won't happen again.
Post  studly November 5th 2009, 9:57 pm
dfree383 wrote:It's not an uncommon problem, spend the extra $$$ on a Kaase pump, it won't happen again.
Please tell me why this happens, i have been out of the BBF world for about three years now stepping back in with a BBF on NOS building right now, should i be worried about this pump?
studly
studly
Post  dfree383 November 5th 2009, 10:02 pm
Stress from vibration. Pretty simple. If your building a high hp expensive motor I'd consider a better pump like kaase's or a titan if you want to stick with a in pan wet sump
Post  Nevs November 5th 2009, 10:10 pm
dfree383 wrote:Stress from vibration. Pretty simple. If your building a high hp expensive motor I'd consider a better pump like kaase's or a titan if you want to stick with a in pan wet sump
I agree. While the Melling can be made to withstand the stress of a high horsepower application, the Kaase is a much beefier casting from the get-go. Well worth it in a high dollar build in my opinion.
Post  studly November 5th 2009, 10:11 pm
I have a titan with jeff johnsons pan in a 638 bbf, but i run 532/557 stock block motors and have not had a failure, just wondered if they had some bad metal or a bad bunch of pumps i know i read somewhere that on some of the chevy motors the new select pump was giving up the ghost and costing some serious money
studly
studly
Post  chuck stevens November 5th 2009, 11:00 pm
If you compare a "new" Melling pump to one that is ...say 10 years old, you'll see the diference. It looks like their accountants are running the show now.
chuck stevens
http://E-MAIL= stevensracingent@aol.com
chuck stevens
Post  Lem Evans November 5th 2009, 11:05 pm
has this happened to anyone else? Brokenpump001Small
has this happened to anyone else? Brokenpump002Small
Post  Nevs November 5th 2009, 11:08 pm
Lem Evans wrote:has this happened to anyone else? Brokenpump001Small
That will make for a slight loss of oil pressure, and ruin your day as well Exclamation Wink
Post  fastford600 November 5th 2009, 11:18 pm
this is how my old pump looked when the crank hit it .
i know some one that their pan was too close and after 3 oil pumps he found out that the pan was hitting it
a hammer fixed it
fastford600
fastford600
Post  Lem Evans November 5th 2009, 11:24 pm
The pan nor the crank hit this one .
Post  richter69 November 5th 2009, 11:25 pm
never had it happen, nor will it ever ......get the sucker out of the pan........... Cool
Post  richter69 November 5th 2009, 11:27 pm
get them Danny Bee guys to stick a pump in the front cover and drive it off the crank like them diesels do................ Exclamation
Post  fastford600 November 5th 2009, 11:36 pm
must have been the shake of that big cam!!!!!!!!!!lol lol! lol!
fastford600
fastford600
Post  c.evans November 6th 2009, 12:34 am
The vibration is what causes the Melling pumps to brake. I suspect it's worse on the bigger power engines, but I don't know for sure. I have had a broken one and replaced it with a Kaase oil pump and have been tickled pink ever since. In fact I just ordered another Kaase pump from Lem last week.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  the Coug November 6th 2009, 12:41 am
x2 on the Kaase pump they are beefy and no more cracks for me.....
Post  bbf-falcon November 6th 2009, 12:45 am
Lots of times ,just a bad tire shake will break the CAST pumps. That won't happen to the K pump. Very Happy
Post  fastfalcon November 6th 2009, 7:50 am
As a matter of fact I did have a bit of tire shake on that pass. Those pictures are exactly what my pump looks like now. So I'll get a Kaase Pump next. Where can I get one? Also, any advice on two bolt conversions?
fastfalcon
Post  Nevs November 6th 2009, 8:10 am
fastfalcon wrote:As a matter of fact I did have a bit of tire shake on that pass. Those pictures are exactly what my pump looks like now. So I'll get a Kaase Pump next. Where can I get one? Also, any advice on two bolt conversions?
Call Lem Evans, 1-877-611-2613. He has the Kaase pump. He'd be a good person to ask about the 4-bolt conversion as well. Idea
Post  Lem Evans November 6th 2009, 11:19 am
c.evans wrote:The vibration is what causes the Melling pumps to brake. I suspect it's worse on the bigger power engines, but I don't know for sure. I have had a broken one and replaced it with a Kaase oil pump and have been tickled pink ever since. In fact I just ordered another Kaase pump from Lem last week.
Charlie
That pump in the picure is your old pump .
Post  chuck stevens November 6th 2009, 1:39 pm
A.B.D. (Already Been Done), just knot by Danny Bee.
chuck stevens
Post  BOSS 429 November 9th 2009, 1:13 am
if i install a melling pump in a race engine i weld a brace to it,one thing people forget is the stress on a pump in a rear sump apt. From bolting down the pickup tube ,ive keep this info to myself for years,but what i do is stress relive( heat till red) the pickup tube,then watch it cool,you would be surprize to see what happenes sometimes, just make sure you heat it as your tighting the nut on main cap stud,or the bolt that holds it to a gurtil,or how ever you hold it down,
-rich
Post  BOSS 429 November 9th 2009, 1:15 am
also we have broke these on the dyno, tire shake, mud racing, but not a one since the brace,or checking the tube
