has this happened to anyone else?
+13
fastford600
chuck stevens
studly
fastfalcon
17 posters
Page 2 of 2 Previous  1, 2
has this happened to anyone else? - Page 2 Empty Re: has this happened to anyone else?
Post  jbozzelle November 10th 2009, 12:03 am
I remember someone stating that it also had to do with using a paper gasket. The gasket would compress over time from vibration and allow the pump to walk and eventually break from the movement.
Post  BOSS 429 November 10th 2009, 12:39 am
we always use a gasket,i have a freind that would surface the block,and not use a gasket, he never had a problem ,with or with out,
5 years ago i pulled down a core engine that was rebuilt by a shop,it had 240,000 miles on it, as i look staring at the oil pump gasket i see one bolt hole and the oil hole is clearly visable,it had spun before the builder had installed the 2nd bolt,lol,this engine ran for over 240,000 miles,lol, both bolts were tighter than heck, this truck was off roaded very hard,.... no breakage
Post  665 falcon November 11th 2009, 9:00 am
If you have some extra cash, you could alway's go to an external pump. It also makes priming the motor a breeze Wink Bobby Z
665 falcon
665 falcon
Post  AlkyPinto November 11th 2009, 12:16 pm
I've seen this a number of times. I would look at
the pickup tube? If the pickup isnt supported by
any bracing to main cap fasteners it adds a lot of
stress and vibration to the pump mount. Especially
long rear sump pickups! I'm using Melling HV pumps
with rear sump pickups in all my BBFs. I run TWO
braces to the pickup tube to main cap fasteners
and have NEVER broken a Melling pump.
AlkyPinto
AlkyPinto
http://www.RichKentRacing.com
Post  jonkaase November 13th 2009, 3:43 pm
Thanks for the advertising! This is why we spent the money to engineer a new oil pump. I broke every one that was ever put on an engine with more than a 4" stroke. We used to weld them up with gessets and brazing, but it was too much work. ... Kaase
jonkaase
Post  billandlori November 13th 2009, 5:09 pm
"Necessity is the mother of invention"
Nice piece Jon!!
Bill
