f/s solid roller cam
I have a comp cams solid roller cam for sale
It has about 100 runs on it
The grind no ff1729r/1866r r 115.0
Lift in .861 ex .814
Duration at 050 in 285 ex 300
Center line 113
lobe sep 115
$175 obo plus shipping
Center line 113
lobe sep 115
rck532- BBF CONTRIBUTOR
Re: f/s solid roller cam
Rick,
Is this from your truck?
If so can you tell me about the combo?
Thanks, Sheldon
Thanks, Sheldon
STR-LGL-70- Posts : 223
598 eliminater block , tfs a heads , tfs tunnel ram, 2 1250 dommys
capri-sun- Posts : 346
STR-LGL-70 wrote:Rick,
Thanks, Sheldon
pm sent
» BBF SOLID ROLLER CAMSHAFTS AND ONE SET USED COMP CAMS SOLID ROLLER LIFTERS
» Using Hydraulic roller lifters on the Comp XR292 R-10 Xtreme Energy Solid Roller cam?
» Solid roller cam
» solid roller cam
» Solid Roller Cam
» Solid roller cam
» solid roller cam
» Solid Roller Cam
