Carb help
Carb help Empty Carb help
Post  bigjohn2007 March 1st 2014, 12:59 am
Well fire car up as long as i hold little gas it will run as soon as i try let idle act like it going shut off.So i pump the throttle it clear up for few seconds then right back as it going shut off.So what need to be adjusted?thanks
bigjohn2007
bigjohn2007
Carb help Empty Re: Carb help
Post  69F100 March 1st 2014, 1:10 am
bigjohn2007 wrote:Well fire car up as long as i hold little gas it will run as soon as i try let idle act like it going shut off.So i pump the throttle it clear up for few seconds then right back as it going shut off.So what need to be adjusted?thanks
Idle screw at the linkage to open the butterflies up a little then try adjusting the air mixture screws once set then you should be able to readjust the idle screw to where you wont it to idle.
Post  bigjohn2007 March 1st 2014, 1:18 am
Set air mixture at 1 1/2 turns out.Must be when i add scoop it change everything far as settings.....
bigjohn2007
bigjohn2007
