Stroker question
Stroker question Empty Stroker question
Post  Jstang85 March 3rd 2014, 3:16 am
I have eagle H beam rods 6.60 length and forged speed pro pistons .060 over and I was wondering if I could run a stroker crank with what I had and if so what would be good.
Jstang85
Stroker question Empty Re: Stroker question
Post  DanH March 3rd 2014, 4:03 am
Jstang85 wrote:I have eagle H beam rods 6.60 length and forged speed pro pistons .060 over and I was wondering if I could run a stroker crank with what I had and if so what would be good.
you could stroke with those parts if you had a 429 to start with to a 460
DanH
Post  Dave De March 3rd 2014, 8:06 am
Actually no.
If the pistons were from a 3.59 stroke then the compression height on the piston is made for that stroke. Likewise for the 3.85 stroke. The pistons will need to be changed.
Post  Jstang85 March 3rd 2014, 8:40 am
Thanks for the help
Jstang85
Post  DanH March 7th 2014, 11:28 am
Dave De wrote:Actually no.
Did you know that flat top forged 429 piston were cut for use with a 460 crank?
DanH
Post  Dave De March 7th 2014, 9:26 pm
Those pistons would need to be cut down .130 which is possible but is that really a stroker?
If you wanted to stroke a 3.85 to 4.3 by only cutting the piston it would need to be cut .225 so that isn't feasible.
If you go 4.3 or 4.5 you want a longer rod with a lighter weight piston.
Post  DILLIGASDAVE March 8th 2014, 12:19 am
Back in the day I think shaving a TRW 429 piston down to use in a 460 was about the easiest way to get a zero deck flattop piston for a 460. If I remember correctly FPP used to cut/sell them.
Post  DanH March 8th 2014, 11:26 am
IF you read my first post, you might understand about stroking a 429 to a 460.
ANY other. no , that means no it won't work
DanH
Post  rmcomprandy March 8th 2014, 12:35 pm
What crankshaft throw JOURNAL size are the connecting rods meant to use...?
