Valve train noise ...
OldRed70
Valve train noise ... Empty Valve train noise ...
Post  OldRed70 March 3rd 2014, 6:28 pm
Ok I have a 514 with Comps hyd roller setup , Comps ultra Gold rockers . And after getting engine together fired up and ran good for about 3 days . Then all of a sudden I am getting a lot of noise from my lifters or it's in the valve train more predominately on drivers side . Sounds like a solid lift lifters out of adjustment . Have readjusted the lash 3 seperate times with the noise being the same every time . Anybody have any answers or suggestions ???? Or is it normal ?????
OldRed70
OldRed70
Valve train noise ... Empty Re: Valve train noise ...
Post  dfree383 March 3rd 2014, 6:38 pm
Could be normal depending on the lifters and lobes. Some hp hydraulic roller stuff can be a little noisy.
But please tell me you are preloading them not lashing them first.
Some lifters can be picky about thickness of oil too.
Post  OldRed70 March 3rd 2014, 6:40 pm
Yep I Pre- loaded them 1st
OldRed70
OldRed70
Post  dfree383 March 3rd 2014, 6:41 pm
OldRed70 wrote:Yep I Pre- loaded them 1st
Who's lifters are you running?
Post  OldRed70 March 3rd 2014, 6:43 pm
Am using Rotella T 15-40 oil . Should I be using a different oil ?????
Am using Comps Lifters
OldRed70
OldRed70
Post  dfree383 March 3rd 2014, 7:00 pm
Might try some regular 10-40 or 30 and see if they quite down.
Post  OldRed70 March 3rd 2014, 7:11 pm
ok will try a different oil
OldRed70
OldRed70
Post  bbf-falcon March 4th 2014, 12:23 pm
Take each rocker off and inspect it thoroughly,roller,bearing,and bearing housing. Had one that kept making tappet noise on right side. Finally found the problem ,but it was a Crane Gold bearing housing busted on the left side. 5 needles had fallen out,luckily they had fallen straight down and all were recovered.
Post  OldRed70 March 4th 2014, 12:35 pm
I have another set of roller rockers I am gonna put on when I get everything back together
OldRed70
OldRed70
Post  bbf-falcon March 4th 2014, 5:50 pm
Check those thoroughly also. Exclamation
Post  OldRed70 March 4th 2014, 6:36 pm
Yes Sir I did . these were some I have ran before and know they are Good . Thanks for the info.
OldRed70
OldRed70
Post  cool40 March 4th 2014, 8:20 pm
Make sure your rockers aren't hitting the valve covers.
Post  OldRed70 March 4th 2014, 8:32 pm
Cool40
They aren't , I have the Tall Ford Racing Covers . that was one of the 1st things I looked at.
OldRed70
OldRed70
Post  quick 52 March 4th 2014, 8:49 pm
I'm not running a hyd roller but the flat hyd. always seem a little loud.
quick 52
Post  cool40 March 4th 2014, 9:22 pm
OldRed70 wrote:Cool40
just a thought as I've had that happen before. not having the noise to begin with is mysterious. Make sure the oil hasn't got fuel diluted for some reason. Keep us posted. ..
Post  Lem Evans March 4th 2014, 9:42 pm
OldRed70 wrote:Ok I have a 514 with Comps hyd roller setup , Comps ultra Gold rockers . And after getting engine together fired up and ran good for about 3 days . Then all of a sudden I am getting a lot of noise from my lifters or it's in the valve train more predominately on drivers side . Sounds like a solid lift lifters out of adjustment . Have readjusted the lash 3 seperate times with the noise being the same every time . Anybody have any answers or suggestions ???? Or is it normal ?????
How are you adjusting them?
I went through this deal with a BBC several years ago....they were Morel hyd. roller lifters. Seems they needed waay less travel than i'd been used to [i.e. screwed down more] than the flat tappet stuff I'd played with.
After I had been 'enlightened' my remark was......"thanks for the instruction sheet that was not there" Rolling Eyes
Post  bbf-falcon March 4th 2014, 10:54 pm
Seems that
happens a lot Lem,they must assume we know w/o instruction
