JAZ valve train organizers question
JAZ valve train organizers question Empty JAZ valve train organizers question
Post  Frank Kramer February 4th 2010, 4:07 pm
Anybody over here that is using them?
Would like to know what the maximum size for the lifters and valves are that they can handle.
Thanks Frank
Frank Kramer
Frank Kramer
http://www.seasideaffair.com
JAZ valve train organizers question Empty Re: JAZ valve train organizers question
Post  bosshoss February 4th 2010, 5:05 pm
I have a couple of them I will have to measure the valve pockets and let you know.
dkp
bosshoss
bosshoss
Post  Doug Rahn February 5th 2010, 8:28 am
Measuring with a scale it looks like 735-001-06 Valve & Spring Tray will hold a 1.968 diameter valve spring, 2.562 intake valve, and a 1.968 exhaust valve. It would be nice though if they had made the pockets a little deeper. The 735-002-06 Rocker Arm & Lifter tray measures 1.125 diameter for the lifters.
Post  Frank Kramer February 5th 2010, 12:53 pm
Doug Rahn wrote:Measuring with a scale it looks like 735-001-06 Valve & Spring Tray will hold a 1.968 diameter valve spring, 2.562 intake valve, and a 1.968 exhaust valve. It would be nice though if they had made the pockets a little deeper. The 735-002-06 Rocker Arm & Lifter tray measures 1.125 diameter for the lifters.
Thanks Doug!
That really helps
Frank Kramer
Frank Kramer
Post  bosshoss February 5th 2010, 11:05 pm
Yep my newer red JAZ ones are the same.
I also have the older black comp cams one and the lifter holes are just barely over 1".
I agree doug the pockets for the valves def should be a little deeper.
dkp
bosshoss
bosshoss
