Vavoline 20/50 Turning Dark after 4 passes ?
Im running C16 racing fuel, and never had this problem before, but just put new oil and filter and made 4 passes at the track and the oil looks dark...I have had this oil in boxes when it was on sale at autozone about 5 years ago...Is it the fuel or bad fuel causing this, Car ran realy well , but hadn't figured out what it turn dark soo soon...First time the car has seen some higher rpms since motor was built new...
colormebad- Posts : 262
Re: Vavoline 20/50 Turning Dark after 4 passes ?
the detergents in the oil is just doing its job and cleaning is the most likely cause. I don't think excessive fuel is the problem unless the oil stinks of gas bad.
Larry Williams- Posts : 884
Larry Williams wrote:the detergents in the oil is just doing its job and cleaning is the most likely cause. I don't think excessive fuel is the problem unless the oil stinks of gas bad.
I have had this Vavoline about 4 years or so , but was bought new...A small ammount of color came from the bottom of each new qt...Here was the new oil and 1 spot that was a different color u can see, then u can see the dark oil i just put in a few days ago, and after 4 runs its dark...I dont smell gas...
I noticed the same thing when pouring in my VR1 20/50. The last few drops were darker than the rest of the quart. Do you think an additive in the oil has separated?
f250mike- Posts : 628
f250mike wrote:I noticed the same thing when pouring in my VR1 20/50. The last few drops were darker than the rest of the quart. Do you think an additive in the oil has separated?
I had bought this oil when it was on sale at autozone about 4 years ago....I just went yesterday and bought a new qt and shook both up and there is a differance in color...New qt is on your right!
When I worked out at the nuclear plant they would dispose of any oil that was 6 months or older, whether or not it had ever been opened...maybe they weren't being overly cautious and wasteful like I thought.
AZFairlane- BBF CONTRIBUTOR
I have another case in the shop from last year. Maybe that $2.00 off a quart has a reason
The additive package in the oil probably has changed since the oil you bought , that's usually why oil goes on sale ! that's what an oil rep told me anyways , 4 years ago here Walmart had 5w30 & 10w30 Quaker State on for sale , 5 litre jugs for $5.99 , called my rep and asked what was the deal? He said a new additive package was out and that was old stock ,so I bought a whole pallet Cheap!!! It takes allot of oil just to change the oil in the all pickups and 3tons!
Hell 5 litre jugs of QS now is $28 !!!
Frank Merkl- Posts : 1524
» Turning Ignition on after turning motor over.
» Went to the dark side...................
» Turning my keys in !!!!
» turning a crank ?
» turning up the pump 92 f250
» turning a crank ?
