turning up the pump 92 f250
turning up the pump 92 f250 Empty turning up the pump 92 f250
Post  Bart Knox January 8th 2016, 9:22 pm
I know its not recommended but is there a safe amount to turn up the pump 7.3 non turbo gutless diesel? I ordered a pyro gage and going to leave truck siting till I get it hooked up but I turned it about a 1/3 of a turn and dose it ever pore the coal out of the stacks under load
Bart Knox
Bart Knox
http://W. B Knox&son LTD Huntsville Ontario
turning up the pump 92 f250 Empty Re: turning up the pump 92 f250
Post  Bart Knox January 9th 2016, 3:28 pm
Also I was looking at a parts truck for the transmission...my overdrive light is on the blink shifting hard probably do for a rebuild...the parts truck is 6.9 wondering if the transmission will bolt on my7.3 already have pedals want to switch to standard same truck just older figured use the driveshafts to
Bart Knox
Bart Knox
Post  zbob January 9th 2016, 7:48 pm
overdrive light blinking is a fault. look at the speed sensor that is part of the speedo assembly. bob
zbob
Post  Bart Knox January 9th 2016, 10:26 pm
I'll check that thanks
Bart Knox
Bart Knox
Post  Bart Knox January 10th 2016, 7:42 pm
Light quite flashing and shifts nice again...guess thats the problem thanks...hopefully it fixed itself for good
Bart Knox
Bart Knox
