Sparkplug Reading ?
+8
61coon
powerstrokeace
DFI429
colormebad
12 posters
Sparkplug Reading ? Empty Sparkplug Reading ?
Post  colormebad March 15th 2014, 10:56 am
2 passes on motor only...What does the reading look like on this plug ?? C16 Fuel
Sparkplug Reading ? DSCF3040_zps0efa0010
colormebad
Sparkplug Reading ? Empty Re: Sparkplug Reading ?
Post  Curt March 15th 2014, 11:43 am
Based on "that" picture, you're lean enough to melt the top of the piston.
Post  cool40 March 15th 2014, 11:47 am
Looks fat on fuel to me.i'd be wondering more about all the rust on it.
Post  Curt March 15th 2014, 11:56 am
I'm seeing specks of shinny stuff. I'm guessing it was driven back to the pits making the color an unusable variable.
Post  colormebad March 15th 2014, 12:04 pm
Curt wrote:Based on "that" picture, you're lean enough to melt the top of the piston.
Well the fumes are soo strong, can't stay in the shop long lol...Fuel pressure is at 7-1/4 ...1250 dominator...Hard to believe its running lean?? That rust color is what concerned me...All plugs are the same...Mabe i was sold some mixed fuel insted of full strength C16...No water in oil or cyl's' and i used a scope and piston tops look fine...Temp never got over 180 at the track
colormebad
Post  DFI429 March 15th 2014, 12:15 pm
Did the motor cool down before you pulled the plugs? IF that's rust, it CAN form rapidly with humid conditions that occur when a motor cools (especially at night, humid days..). How about a shot from the side of the strap? There's plenty of carbon from a rich condition in the first pic..
DFI429
DFI429
Post  Curt March 15th 2014, 12:15 pm
The mixture at idle is not what I would be concerned with. It is at WOT. It would not be unusual for it to be pig fat on idle and starving for fuel at the stripe.
Post  colormebad March 15th 2014, 12:23 pm
DFI429 wrote:Did the motor cool down before you pulled the plugs?  IF that's rust, it CAN form rapidly with humid conditions that occur when a motor cools (especially at night, humid days..).  How about a shot from the side of the strap?  There's plenty of carbon from a rich condition in the first pic..
It was cooler later that evening, and i keep it in my shop except that night i left it on the trailor..I fired it just long enough to back it in the shop the next morning... I will get a side shot in a few mins
colormebad
Post  colormebad March 15th 2014, 12:40 pm
Curt wrote:The mixture at idle is not what I would be concerned with. It is at WOT. It would not be unusual for it to be pig fat on idle and starving for fuel at the stripe.
First time out testing and i was trying to watch and look at everything...Not sure what was going on....
Not much of a track , cause they dont prep much at all...Just a short clip of a somewhat run here..Had to let off....Camera man was drunk also i think....lol
https://www.youtube.com/watch?v=-TJwzyTimzA&feature=youtu.be
colormebad
Post  colormebad March 15th 2014, 1:01 pm
Sparkplug Reading ? DSCF30045_zps0eaecbe9
colormebad
Post  powerstrokeace March 15th 2014, 1:05 pm
You need to kill the motor at the finish line and coast off the track and pull a plug or two and install other plugs to drive back to the pits. if your trying to read plugs after any thing else your wasting your time
Also look like a prety small gap
Ace
powerstrokeace
powerstrokeace
Post  colormebad March 15th 2014, 1:08 pm
powerstrokeace wrote:You need to kill the motor at the finish line and coast off the track and pull a plug or two and install other plugs to drive back to the pits. if your trying to read plugs after any thing else your wasting your time
Ace
I had timing set at 30 total, and plugs were set 25 for nos...But i havent sprayed any yet till i have tested more and get bugs worked out....
colormebad
Post  Curt March 15th 2014, 1:15 pm
As Ace said,,,,,,,, you can't read the plugs if you don't click off at the finish line. Sorry, but these pictures wont tell you anything.
Post  colormebad March 15th 2014, 1:22 pm
Curt wrote:As Ace said,,,,,,,, you can't read the plugs if you don't click off at the finish line.  Sorry, but these pictures wont tell you anything.
Going to get another set of plugs in a few...I will shut her down and change 1 or 2 and check them back at the trailor next test run...
colormebad
Post  DFI429 March 15th 2014, 1:35 pm
Extended idling will pollute your readings, but by your pictures, the center insulator was cleaning minimally, indicating rich or cold (or both), and the strap is 2/3 clean with a haze of carbon, indicating timing may be high, with some idling to haze it over.  Don't dismiss your plugs altogether just because you didn't shut down within nanoseconds of the run.. Wink
DFI429
DFI429
Post  61coon March 15th 2014, 1:45 pm
Ace
^^^^ all this is the correct way unless you get someone to tow you back. I've witnessed guys try to get the most out of a carb idling in the driveway... scratch  Aint gonna happen.
61coon
61coon
Post  richter69 March 15th 2014, 2:51 pm
I hope you were joking with that comment.
Post  Curt March 15th 2014, 4:41 pm
"that" picture has shinny specks on the plug. Is that the way you run yours?
Post  DFI429 March 15th 2014, 5:02 pm
Soo, do ANY shiny specks automatically qualify as a result of a LEAN condition to you regardless of any other indications???  Or just most...  Rolling Eyes
DFI429
DFI429
Post  richter69 March 15th 2014, 5:10 pm
The plugs are junk for reading.
Fresh plugs, start it and do a burnout, click it at the stripe or as soon as you can get off the track (c4 problems).
As far as anything shinny.... Hell it could be antisieze which is a no no in a nitrous motor.
Only thing i get fron that pic posted is is was run a bunch and not in a way to make any tuning descisions......
Post  Curt March 15th 2014, 5:29 pm
That's the reason that "that" was noted.  pirat
Post  colormebad March 15th 2014, 5:31 pm
DFI429 wrote:Extended idling will pollute your readings, but by your pictures, the center insulator was cleaning minimally, indicating rich or cold (or both), and the strap is 2/3 clean with a haze of carbon, indicating timing may be high, with some idling to haze it over.  Don't dismiss your plugs altogether just because you didn't shut down within nanoseconds of the run.. Wink
Unless my timing light is off bad...I had it set on 30* total...Running NGK 10 plugs....C16 gas i hope wasn't bad or mixed with something else...
colormebad
Post  Curt March 15th 2014, 5:32 pm
No, most of the time I would say it was detonation. But he's running very high octane and it doesn't look like he made a full pull..  The picture sucks, and he's wanting us to diagnose his tune up. I guess you have the answer?
Last edited by Curt on March 15th 2014, 6:15 pm; edited 1 time in total (Reason for editing : poor grammar)
Post  colormebad March 15th 2014, 5:33 pm
richter69 wrote:The plugs are junk for reading.
C4 is doing its job and hangin strong...... Wink
colormebad
Post  richter69 March 15th 2014, 5:58 pm
Gettin to neutral at the stripe is a challenge ........
......and you aint leaned on it yet either.
