408 windsor complete
bowsher21
bbfstanger
stock block with splayed 4bolt mains,forged 4in crank,6.2 hbeams,je pistons internal balanced,sfi balancer and flexplate,12.5to1 comp.,custom bullet solid roller,crower lifters,rocker girdles,moroso fox pan,msd dist,cnc'd canfield heads roller springs and ti ret.,think i have the flow sheets, worked super vic ,nos fogger system plumbed up,930 cfm carb,hooker 6223 2in. headers, csr water pump.
makes 600-650hp on motor.
extremely low miles .
$4000
$4000
bbfstanger- Posts : 223
408 windsor
Whats the location?
What/who's crank & rods?
PM sent
PM sent
bowsher21- Posts : 100
Re: 408 windsor complete
im in springfield ohio, eagle crank and rods.
What time did it click off and in what ?
nuclearcobra- BBF CONTRIBUTOR
9.80's @ 135 in a 3000lb car 1.44 60ft .
i may be off a couple on the mph cant remember exactyl i think it was 137.
car needed a better conv. it shoulda 60'd better. shiftin at 6800rpm
bbfstanger wrote:9.80's @ 135 in a 3000lb car 1.44 60ft .
Was that on the hose ? ^^^^^
whitefield- Posts : 2244
Moving along pretty good ! Did you ever get to spray it?
no ,its not plumbed up ,just installed in the intake.
it has hellfire rings if someone does want to spray it.
i always wanted a fogger though lol!
switching over to a bbf Ahead combo, was going to run the windsor but then i sold the C4 setup out of the car.
i have atleast 6500 in it. alt. not included
Yep I figured it was flying when you said cnc Canfields were on it.
Which or what size Canfield heads are on it ? Thanks
1st generation 450-58-1 58cc chambers the 1 means the chambers came cnc'd.
the ports are totallly cnc'd buy someone? coulndt find any signs of who, they flow over320 cfm.
2.08int 1.60 exh.
2nd gen. starts woth 475 p/n
2.08int 1.60 exh.
is the windsor still for sale
Just wondering if you still got the windsor for sale give me a call if you do 6162990529 my name is Scott thanks
svb1978- Posts : 2
