Push-Loc Hose
+9
Mustang-junky
342g
bigjohn2007
13 posters
Push-Loc Hose Empty Push-Loc Hose
Post  bigjohn2007 March 22nd 2014, 9:13 pm
Well as usually I'm trying new things. I bought some push-loc hose and fitting thinking I could plum up my reg easy and I got a rude awaking lol. I grease it up with WD-40 and push like hell with the fitting in a vise.#8 got half way and stopped so I put the hulk on it with no results lol,#6 slide right on up to the ring on top of fitting.So could some of you guys explain what has worked the best for you?thanks
bigjohn2007
bigjohn2007
Push-Loc Hose Empty Re: Push-Loc Hose
Post  69F100 March 22nd 2014, 9:39 pm
bigjohn2007 wrote:Well as usually I'm trying  new things. I bought some push-loc hose and fitting thinking I could plum up my reg easy and I got a rude awaking lol. I grease it up with WD-40 and push like hell with the fitting in a vise.#8 got half way and stopped so I put the hulk on it with no results lol,#6 slide right on up to the ring on top of fitting.So could some of you guys explain what has worked the best for you?thanks
I use a small propane torch to heat the hose just a little and spray the fitting before I push it on they are a pain in the rear for sure sometimes
Post  bigjohn2007 March 22nd 2014, 9:46 pm
Yep the name is what sold me as usually always a catch or trick.
bigjohn2007
bigjohn2007
Post  whatbumper March 22nd 2014, 11:11 pm
Sorry for your bad luck but I've never really had issues with them.  And we use up to size -20.  I guess all those years of hay hauling pays off.  Laughing
Post  bigjohn2007 March 22nd 2014, 11:31 pm
whatbumper wrote:Sorry for your bad luck but I've never really had issues with them.  And we use up to size -20.  I guess all those years of hay hauling pays off.  Laughing
You my HERO lol
bigjohn2007
bigjohn2007
Post  richter69 March 23rd 2014, 12:01 am
kung-fu grip ftw.......
Post  jasonf March 23rd 2014, 8:01 am
Aeroquip makes a lubricant (oil) for assembly that helps a bit. I have found some can go on reasonably and some are just a real bugger. I used to put the hose in a vise and just leave enough sticking out for the fitting. Then push like hell. I see Koul tools has a vise/press that pushes them in as well. I have also had some luck by turning the hose with the fitting facing down and pushing the hose onto the fitting (use a piece of wood below the fitting and tape it up to protect from scratches.
Here is the tool I have. It's made of plastic and while it flexes it has not broken yet.
http://www.speedwaymotors.com/Aeroquip-FBM3632-Push-On-Fitting-Tool-for-AN4-AN6-AN8,941.html
Vise press.
Push-Loc Hose Attachment
After a quick google search I read the best way is to heat the hose in boiling water for about a minute and apparently they slip right on. I also read to use liquid soap not oil because it will dry. (go figure).
Post  whatbumper March 23rd 2014, 11:14 am
I really kind of simulate that tool above.  Not to sound too ridiculous I have a stance.  Fitting in left hand against inside of left knee, hose in right hand with hand against right knee.  Then I press my knees together and force the hose and fittings together while twisting a little (hose, not body, it's not some weird dance or something).
Don't know if that means anything to anyone but that's what I really do.
Post  342g March 23rd 2014, 12:15 pm
whatbumper wrote:I really kind of simulate that tool above.  Not to sound too ridiculous I have a stance.  Fitting in left hand against inside of left knee, hose in right hand with hand against right knee.  Then I press my knees together and force the hose and fittings together while twisting a little (hose, not body, it's not some weird dance or something).
Could you post a pic, of that position, some of us might be too old to get in that stance.  Very Happy
342g
342g
Post  Mustang-junky March 23rd 2014, 12:53 pm
I have always just spit on it and pushed it in.  Very Happy  Some lube and muscle.
90* fittings are a bit harder than straights.
Jess
Mustang-junky
Mustang-junky
Post  Curt March 23rd 2014, 2:05 pm
With Push-Lock hose, I think it is important to use the same name fittings and hose. You may be already, but just throwing that out there.
Post  cool40 March 23rd 2014, 2:51 pm
Curt wrote:With Push-Lock hose, I think it is important to use the same name fittings and hose. You may be already, but just throwing that out there.
^^x2! I used some off brand stuff for most of my oil lines and it all worked great.I had to use one earls fitting I already had and thought I'd never get that sob on.
Post  whatbumper March 23rd 2014, 3:17 pm
It might be NWS if I posted it.  Lol
Pretty much any of the ideas here would work.
Post  bigjohn2007 March 24th 2014, 1:47 pm
That some funny shit Laughing
bigjohn2007
bigjohn2007
Post  DeepRoots March 25th 2014, 9:07 am
I use these at work all the time, especially for air lines.
Only trick I've got that hasn't been covered, is I normally install the fitting either in place or into something stationary and solid before I try putting the hose on.
DeepRoots
Post  nuclearcobra March 25th 2014, 8:12 pm
I've only used aeroquip hose and fittings with earls assembly lube and I have the aeroquip aluminum vise jaw inserts for my vise to hold it and its easy as pie to do, I will say that before the earls lube when I did a car it was hell to do, I actually struggled with some so bad trying to twist the hose on I ripped it. But with the lube its easy , almost too easy like ya think its gonna leak for sure.
nuclearcobra
nuclearcobra
Post  bigjohn2007 March 25th 2014, 8:15 pm
Thanks i'll give the lube a try. Very Happy
bigjohn2007
bigjohn2007
Post  nuclearcobra March 25th 2014, 8:29 pm
and get the vise inserts they work great.
nuclearcobra
nuclearcobra
Post  bigjohn2007 March 25th 2014, 8:32 pm
I found the assembly lube but can't find the vise insert on Jeg's website.
bigjohn2007
bigjohn2007
Post  nuclearcobra March 27th 2014, 8:54 pm
It's #023-Fcm-3661 in JEGS
nuclearcobra
nuclearcobra
Post  bigjohn2007 March 27th 2014, 11:21 pm
nuclearcobra wrote:It's #023-Fcm-3661 in JEGS
Thanks again
bigjohn2007
bigjohn2007
Post  nuclearcobra March 28th 2014, 11:16 am
No problem , good luck with it , I did my whole car with it from cell to carb, also -8 push loc is bigger id than -8 braided.
nuclearcobra
nuclearcobra
Post  Gregaust March 29th 2014, 5:02 am
I like to use Brake clean or Carb cleaner , something that evaporates when fitting the hose . Makes for a nice tight fit as opposed to a lube that will stay there .
Gregaust
Post  nuclearcobra March 29th 2014, 10:26 am
That lube Doesn't stay there , when you cut a hose off there's no trace of it.
nuclearcobra
nuclearcobra
Post  Dave C. March 29th 2014, 11:06 am
Will that hose pass tech..... ?
Dave C.
