AN fittings and hose
Where do you guys buy your AN fittings and hose from? I use a few places online as my local shop stocks hardly anything. The problem I have is I can't seem to ever find one place that has everything I need. I always end up getting some here and some there. Especially if you want something other then the standard blue or blue red like black.
I use:
http://www.anplumbing.com (Earls)
http://www.racerpartswholesale.com/ Has a good selection of Aeroquip
http://www.goodvibesracing.com has helped me out with oddball stuff like ORB fittings XRP fittings
http://www.racepartsolutions.com carries Frago fittings
I use:
jasonf- BBF CONTRIBUTOR
Re: AN fittings and hose
Fortunately, I have a large speed shop about 20 Min. away and, if that fails...it's only another 25 Min to a very well stocked Aeroquip dealer. BEWARE of the house brand(Jegs and Summit) and other off shore fittings...especially any with o-rings or seals in them UNLESS...you like leaks.
the parker store. (or any hydraulics place)
called JIC
called JIC
Diggindeeper- Posts : 800
IcallhimGeorge- BBF CONTRIBUTOR
» Push-Loc Hose
» 1/2" fuel hose
» what kind of setup you guys running waterpump wise an fittings or regular hose with clamps ??
» 4an hose ends, tees, and hose
» AN fittings -16 vs -20
» 1/2" fuel hose
