what kind of setup you guys running waterpump wise an fittings or regular hose with clamps ??
+10
56Tbird
514Fox87
nitro717
Larry Williams
the great pumpkin
Barney
5pointslow
14 posters
looking at getting a electric water pump and gonna get a radiator and fan setup as well , but i see some guys run an fittings and i have seen the reguar hose and clamp ,
if someone has any ideas or a direction on this would be helpful and i am using front plate also if that matters
thanks
thanks
5pointslow- Posts : 1408
Re: what kind of setup you guys running waterpump wise an fittings or regular hose with clamps ??
I run regular hose and clamps on my mustang, been thinking about changing everything to AN
is there any gains or rules to it or just preference ?
I dont think there are any rules, just seems safer.
AN fittings here......but I'm a
Just remember you can go to any parts store and get hoses and clamps.more then likely other racers will have a hose or clamps as well.the an fittings are nice but over tighten them and you may have a problem.problem being is do you have a spair.
the great pumpkin- Posts : 6
the great pumpkin wrote:Just remember you can go to any parts store and get hoses and clamps.more then likely other racers will have a hose or clamps as well.the an fittings are nice but over tighten them and you may have a problem.problem being is do you have a spair.
I think I saw you guys at Byron this last weekend............
an fittings on both cars
Larry Williams- Posts : 884
you ever end up pressurizing your system it will blow a regular hose off...i know of a guy this happened to and ended on his lid.
nitro717- Posts : 92
Summit Racing SUM-390036 - Summit RacingĀ® Stainless Steel Flexible Hoses. Check these out I have had good luck with them.
514Fox87- Posts : 436
I put a AN fitting on my top hose this year going into a rubber hose at the radiator. If I ever have to replace my radiator I will go to all AN lines. I like them alot better myself.
56Tbird- BBF CONTRIBUTOR
5pointslow wrote:is there any gains or rules to it or just preference ?
The AN Stuff is better IMO But it is alot more expensive.
on the flip side the regular stuff lasts for years and is use on all OEM stuff.... So....... IMO Nothing but some safety to be gained and the AN stuff does look cool.
All A-N stuff on my car. Never have to worry about it.
BigDave65- Posts : 567
What size AN fittings are you all running for radiator hose
darren- Posts : 64
darren wrote:What size AN fittings are you all running for radiator hose
I'm using -16
John Myrick- BBF CONTRIBUTOR
2 -10's going in and one -12 coming out, the fitting on top of the radiator is a -10 with a -10 to -12 adapter. I also use the smaller 20gpm pump.
I use a CSR water crossover, Shogun remote pump, -10 lines and a dual pass Scirocco style Griffin radiator.
jbozzelle- Posts : 3705
I set mine up with -16 hoses ,csr pump and a jegs aluminum radiator,
so i was wondering if -16 is to small diameter hose for a street car
darren- Posts : 64
» AN fittings and hose
» Alky Hose and Fittings
» 12an fittings and hose
» 4.5" Scat cast crank, how much HP are you guys running through them?
» whats your guys take on running a dry sump set- up?
