4.5" Scat cast crank, how much HP are you guys running through them?
D. Sea
Greg_P
I'm a little worried about the one in my 545. Just wondering how much these buggers have been taking in the real world.
Greg
Greg
Greg_P- Posts : 1009
Re: 4.5" Scat cast crank, how much HP are you guys running through them?
Tough to say, some last, some break....
Well, I had the crank magnafluxed two seasons ago and it checked out fine..... but that was before the 200 shot.
I'm debating whether or not I should step up to a forged crank, but $$$ is kinda tightm you know how it is.
I'm probably gonna have the crank magnafluxed again this winter just to check, but I was really wanting to see how hard guys have been pushing these cranks out there in real life.
This engine is probably around 850HP on the spray.
Greg
Greg
I'd say your at or a little above the realistic limit IMO, call Adney and get a forged one he can even balance it to you bob weight so theirs no hastle.
Adney's definitely the man I would go to for a crank. He's the one who set me up with what I have now, so I already know his service and price can't be beat.
Greg
Greg
dfree383 wrote:I'd say your at or a little above the realistic limit IMO, call Adney and get a forged one he can even balance it to you bob weight so theirs no hastle.
Ditto
![What a Face](https://2img.net/i/fa/i/smiles/fresse.png)
D. Sea- Posts : 2768
If it was an Eagle you would already have the answer to your question
![Laughing](https://2img.net/i/fa/i/smiles/icon_lol.gif)
![affraid](https://2img.net/i/fa/i/smiles/affraid.gif)
I had one in my first 557...that motor made 821 hp...it lasted exactly 260 passes...mostly 1/8 mile with some 1/4. The motor was never turned past 6800.
This was a N/A deal, no spray ever, shifted at 6200 bracket motor...FWIW.
Treeyasoon- Posts : 759
i have a 4.3 scat cast in one of ours its a bracket motor over 300 passes so far but
you never know when it will go we have a new scat billet in the big motor.
![No](https://2img.net/i/fa/i/smiles/kopfschuettel.gif)
studly- Posts : 512
I'm using a Scat 4.3" cast crank in my 532 street engine and it makes 650 hp/675 ft lb. I have the limiter set at 7200rpm but only spin it to around 6500rpm. I have approximately 4000 street miles and a handful of passes on it. Everything OK so far.
busta- Posts : 28
» New Scat Cast Crank 4.300" stroke
» Scat/Motorsport 4.300 cast crank
» scat cast 4.5 stroke crank
» Limits of SCAT cast steel 9000 crank?
