Limits of SCAT cast steel 9000 crank?
Mark O'Neal
tfsbbf466
I have a SCAT cast steel 9000 crank it is a 4.5" stroke.
I am putting together a 557....14:1, solid roller cam, Edelbrock heads with major porting work (port walls are getting thin!!), D0VE-A block with Milodon splayed 4 bolt caps.
I expect that it will make 750-800 but I also want to spray it with a 250 shot. The general consensus is that the crank is the weak link in the parts combo.
What have these things handled before breaking/cracking, or completely exploding??
I can change direction and go with a forged unit now, before its all assembled....good idea or bad??
BBFTorino- Posts : 999
Re: Limits of SCAT cast steel 9000 crank?
It should be fine until you spray it. At this output, I'd spend the extra for a forged unit.
I exploded an eagle 4.14 cast crank in a mild pump gas 512 on a 73 jet. It lasted 2 years or so but it grenaded. Only thing left was the cam surprisingly and the heads were ok with only a few bent valves. Oiled down my favorite test spot lol
tfsbbf466- Posts : 180
tfsbbf466 wrote:I exploded an eagle 4.14 cast crank in a mild pump gas 512 on a 73 jet. It lasted 2 years or so but it grenaded. Only thing left was the cam surprisingly and the heads were ok with only a few bent valves. Oiled down my favorite test spot lol
Eagle cranks and Scat cranks are not near the same strength.
I didn’t realize that cast vs cast. My originally crank in the motor was a scat 4.15 cast but the converter ballooned and knocked the thrusts out of it. Replaced it with an eagle since it was cheaper and it already had no name rods. Paid the price in the end.
Saving money is expensive.....
Mark O'Neal- Posts : 286
Mark O'Neal wrote:Saving money is expensive.....
No kidding!! I already had the crank, and it was originally intended for to be used in a 557 with low compression, mild cam and more street friendly environment. It was to be a high torque, low RPM deal for a F-350 dually truck. But I want to get my Torino back on the track!!
The motor is still all apart right now, so upgrading to a forged crank at this point is going to happen!!
X2 bite the bullet now.
dfree383 wrote:Mark O'Neal wrote:Saving money is expensive.....
The people I work for "save" money like that every day....
jasonf- BBF CONTRIBUTOR
Reminds me of the Flexy Flyer Cast 4.5 Crank that wiped out all of the bearings in Blakes 557 at one of our tech seminars. I believe it was making right at or near 800 HP when the oil pressure took a nose dive.
That was an Eagle 4.5" IIRC
D. Sea- Posts : 2768
There is an actual reason why manufacturers make specific limits on their parts. Taking the parts beyond those limits can cause failure. A 4.500 stroke cast crank at 7,000 rpm is more likely to fail than the SAME crank ( or material) at a 4.300 (or less) stroke. Less stroke overlap , higher centrifugal forces , etc . will cause failure sooner. That is simple physics. Change material to a forging and the margin of safety increases dramatically. Change to a high end steel ( like Bryant uses for example) and crank life is extended even further. As Randy and others have already said saving money up front can be more expensive in the long run. Common sense must be exercised , not ignored.
gt350hr- Posts : 662
The reason manufacturers make specific recommendations is because customers ask. So do lawyers. Horsepower is not the primary basis for selecting a part and the manufacturer has no idea what the end user is going to do with it.
A rod manufacturer has no idea if you're running a Moleculite piston.....or a brick.....or if you're running 6,000 or 12,000 rpm, for example.
Why did ARP recommend 20 torquings for a rod bolt's life? Because they had to pick a number. There is no specific number of torquings a bolt is good for.
And it's not like you guys listen anyway......
I will substitute this crank for a forged steel unit. And this cast crank will go back to being for a truck low RPM torque motor!!
Mark O'Neal wrote:The reason manufacturers make specific recommendations is because customers ask. So do lawyers. Horsepower is not the primary basis for selecting a part and the manufacturer has no idea what the end user is going to do with it.
Really? I didn't realize manufacturers were so stupid.
» scat 9000 crank
» Scat 9000 vs stock crank
» New Scat Cast Crank 4.300" stroke
» Scat 9000 opinions
» Scat/Motorsport 4.300 cast crank
