AN fittings -16 vs -20
+7
Tony M
D's557BBF
11 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Anybody out there using a radiator with the bungs welded on? If so, are you using a -20 fitting or a -16 fitting. I want to have the bungs welded onto my radiator and I don't know what size would be best for a BBF?
Is this a case of the bigger the better?
D's557BBF- Posts : 1186
Re: AN fittings -16 vs -20
What size AN fitting do you have on your water pump? and on you Water Neck on the Manifold?
dfree383 wrote:What size AN fitting do you have on your water pump? and on you Water Neck on the Manifold?
nothing yet, I still have to buy all of that. They make whatever you want for all the parts you just named...
Either I buy all -20 or all -16 PARTS
bigger don't hurt anything but your wallet.........
I use -12, that -16 and bigger is a pita to work with.
Your Running Alky too......
I use 12 on gas/nitrous set up with no problems.
Tony M- Posts : 479
I used -10 on the dragster. For the little bit we ran it at the house and track it seemed to work just fine... I'm almost positive Mikey ran -10 on it when he had it too. I would assume he did since that's what the radiator had welded to it.
Sometimes it's counter productive to move too much water through a radiator...
jbozzelle- Posts : 3705
I run -8, just how much water are you wanting to move?
Curt- Posts : 2791
dfree383 wrote:Your Running Alky too......
I ran it on gas this way too, only exception was the outlet was a -10.
D I have some -16 hose ends and hose I'll make ya a smokin deal on, shits brand new.
Curt wrote:I run -8, just how much water are you wanting to move?
Curt I don't know, just trying to see what will be better. I decided to switch from hose's to AN lines last night!! So I’m just searching for answers right now. I will be driving the mustang on the street sometimes also...
Instead of -20 vs -16, it now looks more like -16 vs -12
richter69 wrote:dfree383 wrote:Your Running Alky too......
I'll call ya in a few Jon...
Think about how much water goes through a 5/8" water hose. That would be equal to a -10.. No need for the big expense of large fittings and hose.
Curt- Posts : 2791
if your running on the street yo want big hose and a Thermostat, Eveybody else it telling you about race cars.... they don't sit in traffic or run for super long periods. ........
D if you can get pics on your cell pm me the # and I'll send some pics of this stuff to your phone, if not I'll post um up, just easier to text um
if it's between -12 and -16 now I would go with -12. and for the street driving don't worry about the thermostat. we do upgrades for some guys with classic cars that drive in parades. that were worried about which thermostat to use. that is the beauty of an electric pump you can control when the water flows. if it flows too much, which I have never had, then put a wacher inline to restrict the flow.
whatbumper- Posts : 3024
jbozzelle wrote:I used -10 on the dragster. For the little bit we ran it at the house and track it seemed to work just fine... I'm almost positive Mikey ran -10 on it when he had it too. I would assume he did since that's what the radiator had welded to it.
Actually, I ran -8 on the old car AND the new car. The bungs on the old rad were -8 . No issues on the old one and none yet on the new one.
QtrWarrior- Posts : 2703
dfree383 wrote:if your running on the street yo want big hose and a Thermostat, Eveybody else it telling you about race cars.... they don't sit in traffic or run for super long periods. ........
Except that at idle, there is no load on the engine. And if you have a good electric fan, there shouldn't be an issue..
Been there.......Done it... in a "street car".
whatbumper wrote:if it's between -12 and -16 now I would go with -12. and for the street driving don't worry about the thermostat. we do upgrades for some guys with classic cars that drive in parades. that were worried about which thermostat to use. that is the beauty of an electric pump you can control when the water flows. if it flows too much, which I have never had, then put a wacher inline to restrict the flow.
Is there another term for "wacher inline" I have no ideal what that is...LOL!
washer, he types like i do lol.
get back to work D.......................
I'm home now waiting on my pics!!!
I'm still at work fixing your trucks.................sorta lol.
QASIS................
QtrWarrior wrote:jbozzelle wrote:I used -10 on the dragster. For the little bit we ran it at the house and track it seemed to work just fine... I'm almost positive Mikey ran -10 on it when he had it too. I would assume he did since that's what the radiator had welded to it.
I plan to use the same pump/radiator/fan combo in the Mustang too.
Doesn't Shogun still make that Tik-Tok box? I recall some guys I used to race with years ago having trouble keeping cars cool and installing that box from Shogun fixed it alot. All it did was automate/alternate the fan and pump until the engine cooled down...
Or this from Altronics http://altronicsinc.com/
Curt- Posts : 2791
Page 1 of 2 • 1, 2
» Question about AN fittings?
» AN fittings and hose
» Cooling products
» Trouble splitting heater hoses
» need some -3an fittings
» Cooling products
Page 1 of 2
