tech help on cam specs
tconnection
Tech help on cam specs.
295/303 adv 260/268@.050 640/634 lift on a 112ls. About what would these specs require, gear wise weight of car and stall converter wise 12.5 cr with a dove head and victor intake?
Thanks for any info.
tconnection- Posts : 866
Re: tech help on cam specs
How big of engine?
You're kinda doing it backwards, you want to cam to the car...... Not car to the cam.
maybe he already has the cam and not the car?????dfree383 wrote:How big of engine?
dfree ur right. I was lookn at that Howards solid flat tappet. Any suggestions? Its a 466ci c6 28in tire, 3200lb, 12.5 to 13cr., 4.10 or may 4.30gr.
Thanks for any holp
Thanks for any holp
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=1021&sb=2
If you are looking for a shelf grind this on works well in a 466.
tconnection wrote:dfree ur right. I was lookn at that Howards solid flat tappet. Any suggestions? Its a 466ci c6 28in tire, 3200lb, 12.5 to 13cr., 4.10 or may 4.30gr.
Thanks for any holp
Heads...? Intake ...? Carb ...? Headers ...? Converter...?
rmcomprandy wrote:tconnection wrote:dfree ur right. I was lookn at that Howards solid flat tappet. Any suggestions? Its a 466ci c6 28in tire, 3200lb, 12.5 to 13cr., 4.10 or may 4.30gr.
Thanks for any holp
Get with Randy he can design you a cam that will work better than the off the shelf he design the one in my 460 and it and the lifters was only like $30 more than the off the shelf and it will be built to the engine and car. But he will need all the engine info and car info 1st I have no complaints with mine.
Oh and listen to him he know more about these engine than most of us on here
Lem had a cam n lifter set a while back that was right about the same,,,, I run it, with a tadd more comp,,, Might check with Him.tconnection wrote:dfree ur right. I was lookn at that Howards solid flat tappet. Any suggestions? Its a 466ci c6 28in tire, 3200lb, 12.5 to 13cr., 4.10 or may 4.30gr.
Thanks for any holp
samiam- Posts : 240
Randy, how much for cam and direct lube lifters? Its gonna b a 466, 12 to 13:1 cr, doves with some port work,victor intake, 4000 stall, 3300lb car, c6, 410 gear, about a 1000cfm carb
tconnection wrote:Randy, how much for cam and direct lube lifters? Its gonna b a 466, 12 to 13:1 cr, doves with some port work,victor intake, 4000 stall, 3300lb car, c6, 410 gear, about a 1000cfm carb
Given those specs, that "off the shelf" cam you mention would probably be OK.
You have a PM.
» 514 blower build question
» Got another cam, need specs
» help with cam specs
» Need Help build questions
» Ignition timing with SCJ heads
