514 blower build question
I have a 514 stroker crate motor just wondering what I need to do to make my motor hold up and be reliable putting this alcohol injection and blower on it. Trying to figure out what it would cost to build this or if I'd be better off selling my motor and starting over.
I have a buddy selling Enderle bird injection got alcohol,K-Valve,End.80A Fuel Pump,Filter fuel shut off cable,ETC...
He also has a BDS 8-71 blower and intake for bbf
This whole setup I can get from him for a little over 3000 it's all barley used.
This is my motor :here are all specs
http://www.fordracingparts.com/m/part.asp?p=6188
I don't want to throw this on and grenade everything so what is a realistic number what my cost will be to make this motor support a blower and will I break 1000 hp with this combo?
Thanks for any and all advise
Mudrazer- Posts : 9
SPECS:
SPECS;
Has Eagle® H-beam connecting rods M-6200-C514
625 HP @ 6250 RPM
600 ft./lbs. of torque @ 4800 RPM
9.8:1 compression ratio
Sturdy 460 2-bolt main short block M-6009-D514
Cast nodular iron 4.300" stroker crank
Ford Racing forged aluminum dished pistons with full floating pins
Mechanical roller lifter camshaft with .647" lift, 254° intake and 258° exhaust duration @ .050" lobe lift
M-6049-SCJB “Super Cobra Jet” aluminum cylinder heads
M-9424-H429 “Victor Jr.” single plane intake manifold
1.73:1 ratio aluminum roller rocker arms
625 HP @ 6250 RPM
Mudrazer- Posts : 9
» Budget Blower Engine Build
» newbie engine build question
» 351 Boss build question.
» Engine build Question.....
» Engine build question??? a little more help , Please!
