newbie engine build question
I am putting together my short block and I noticed that on the main journal #1 that the bearing is covering most of the oil passage. Is this normal or should I Drill/grind the bearing to unblock the oil passage. The crank is Scat, the connecting rods are scat and the bearings are Clevit.
r1ckyb0nd- Posts : 8
Re: newbie engine build question
Im no expert but i would say thats good.
No Problem
from what i see that looks ok...
Kiwi Petrol Head- Posts : 5
» Newbie Need 429 Build Info!!
» Engine build Question.....
» Engine build question??? a little more help , Please!
» Compression/Engine build question
