Engine build question??? a little more help , Please!
Engine build question??? a little more help , Please! Empty Engine build question??? a little more help , Please!
Post  racinghabbit January 6th 2014, 11:30 pm
I have a stock crankshaft in a motor and i also have a set of SRP154166 pistons for a 501 stroker. My question is , Is there any eagle rods i could put in this motor so i can use the pistons??? trying to save money.... thanks
racinghabbit
racinghabbit
Engine build question??? a little more help , Please! Empty Re: Engine build question??? a little more help , Please!
Post  rmcomprandy January 7th 2014, 11:07 am
racinghabbit wrote:I have a stock crankshaft in a motor and i also have a set of SRP154166 pistons for a 501 stroker. My question is , Is there any eagle rods i could put in this motor so i can use the pistons??? trying to save money.... thanks
not "OUT OF THE BOX" ...
C A T , (before they went out of business), used to offer a 6.800" length rod with a Ford journal size but, the small end would need to get re-bushed to .990" for your pistons; then it would be close.
Just have that crank offset ground to 4.140" stroke with a 2.200" journal and get that assembly balanced ...THAT would be the least expensive way to make good use of those pistons.
Last edited by rmcomprandy on January 7th 2014, 11:12 am; edited 1 time in total (Reason for editing : spelling)
Post  racinghabbit January 7th 2014, 1:15 pm
what rods would I buy then?
racinghabbit
racinghabbit
Post  rmcomprandy January 7th 2014, 1:22 pm
racinghabbit wrote:what rods would I buy then?
With an offset ground crank ... pick a brand and type of 6.700" length rods for the 2.200" journal size with a .990" diameter wrist pin; there are several available from a lot of companies.
Post  racinghabbit January 8th 2014, 9:29 pm
Can i use a stock 1968 crankshaft for this? If i have it offset ground are the oil gallies going to be good location still?
racinghabbit
racinghabbit
Post  dfree383 January 9th 2014, 4:32 pm
racinghabbit wrote:Can i use a stock 1968 crankshaft for this?  If i have it offset ground are the oil gallies going to be good location still?
that crank will work fine
Post  racinghabbit January 24th 2014, 6:55 pm
EAGLE CRS67003D H BEAM CONNECTING RODS How about these??? Look like it to me but just double checking....
racinghabbit
racinghabbit
Post  racinghabbit January 27th 2014, 1:27 pm
... last post help...
racinghabbit
racinghabbit
Post  70FB January 27th 2014, 4:53 pm
racinghabbit wrote:EAGLE CRS67003D H BEAM CONNECTING RODS How about these??? Look like it to me but just double checking....
Thats it. I have those in mine.
70FB
70FB
Post  racinghabbit January 30th 2014, 3:36 pm
Thanks for the help !
racinghabbit
racinghabbit
Post  racinghabbit January 30th 2014, 3:40 pm
perfect
racinghabbit
racinghabbit
