iron cj headed 460
+9
tfsbbf466
Dave C.
fastbarry
13 posters
iron cj headed 460 Empty iron cj headed 460
Post  fastbarry March 30th 2014, 7:22 pm
i just put a "new" engine together. i am heading to the dyno the end of next week. i am curious if any one has a guess as to what kind of numbers we might put out.
4.360 bore early efi small dish pistons
3.85 stroke oem crank
stock truck rods w/ arp bolts
dooe-r heads with bowl guide and short turn work done as per Scotty's website
solid flat tappet cam .624/ .648 lift
252* / 260* @.050" lift
port matched victor intake w/ 1250 dommi and 2" open spacer.
zero deck block
11.25 comp.
2" headers w 3.5 collectors
i plan to rev limit at 6500 rpm.
this is a grenade motor to get me by for a while on the street in a light weight f100 2wd.
how do you guys think this will run.
barry
fastbarry
fastbarry
iron cj headed 460 Empty Re: iron cj headed 460
Post  dfree383 March 30th 2014, 7:51 pm
550ish...... Carbs going to be a little big if the truck is heavy, with light gearing and it has a street converter
Post  rmcomprandy March 30th 2014, 7:58 pm
dfree383 wrote:550ish...... Carbs going to be a little big if the truck is heavy, with light gearing and it has a street converter
That would be my guess, also.
Post  fastbarry March 30th 2014, 8:48 pm
3800 lbs.  And a 3500 stall.   3.50 gears and a 28" tire.
a have a 750 dp as well that i will be testing on the dyno.
the predecessor to this motor was a .040 over rebuilder short block with  with pistons about .030 in the hole and a 20ish cc dish.   same heads cam intake and carb.    i ran it in my jet boat for 2.5 seasons.   when the pump was fresh with an A impeller it turned right at 5600 rpm.   blowby became to bad and was making a mess in the engine bay so i pulled it and put it in a 4x4 off road race truck and ran it as long as i could.
after a summer of spinning it 7200-7300 on every striaght away and over heating it countless times it said no more and i lost oil pressure and had to pull it.   i dont think i could have asked for any more out of a honest wrecking yard short block.
i figured it should respond to more compression and proper quench in this latest grenade build.
am i possibly leaving any power on the table with this cam?
this engine is going in the truck in my avatar
fastbarry
fastbarry
Post  dfree383 March 30th 2014, 10:01 pm
Try a smaller carb. 950 or 1050, the 1250 is going to make more power on the dyno, but the smaller carb should accelerate your truck better.
IMO the cam will work OK
Post  IDT-572 April 1st 2014, 10:19 am
537.9 hp
Post  Dave C. April 1st 2014, 10:54 am
If it's a grenade engine I wouldn't waist it on the dyno.
Dave C.
Post  richter69 April 1st 2014, 11:13 am
537.91
Post  dfree383 April 1st 2014, 9:27 pm
537.92..... Razz
Post  tfsbbf466 April 1st 2014, 11:54 pm
Sounds like a solid combo to me. I've sprayed the balls off a cast piston iron head 466 with no problems. Not a huge shot (150-175) but I sprayed it often. Motor is still together today. Are you going with the Mad dog headers? I'd say 575hp if the heads flow well.
tfsbbf466
Post  fastbarry April 2nd 2014, 1:21 pm
tfsbbf466 wrote:Sounds like a solid combo to me. I've sprayed the balls off a cast piston iron head 466 with no problems. Not a huge shot (150-175) but I sprayed it often. Motor is still together today. Are you going with the Mad dog headers? I'd say 575hp if the heads flow well.
i am building my own headers. i am not sure what application headers might fit.
the truck has a '05 crown vic police interceptor front suspension and the engine sits low and far back. I have probably built a dozen sets of headers so that is not a big issue.
fastbarry
fastbarry
Post  tfsbbf466 April 2nd 2014, 2:24 pm
Got ya I thought you were still running I beams like myself. Any pics of the front suspension install?
tfsbbf466
Post  fastbarry April 7th 2014, 10:55 pm
tfsbbf466 wrote:Got ya I thought you were still running I beams like myself. Any pics of the front suspension install?
here are a few pics. forgive the dirty appearance.
iron cj headed 460 20140402_114904
iron cj headed 460 20140402_114848
fastbarry
fastbarry
Post  Mike R April 7th 2014, 10:57 pm
I'm diggin the Crown Vic front suspension
Post  fastbarry April 7th 2014, 11:26 pm
the crown vic front was a very easy swap also.
this is the truck before the suspension swap
iron cj headed 460 Truck
fastbarry
fastbarry
Post  tfsbbf466 April 8th 2014, 12:12 am
Looks good. My dad wants me to do the swap but I want to keep the I beams. How much weight do you think you dropped?
tfsbbf466
Post  fastbarry April 8th 2014, 12:17 am
tfsbbf466 wrote:Looks good. My dad wants me to do the swap but I want to keep the I beams. How much weight do you think you dropped?
i dropped a solid 200- 250lbs from the steel stock stuff to the CV stuff.
fastbarry
fastbarry
Post  tfsbbf466 April 20th 2014, 7:11 pm
That's pretty sweet. My truck would be around 3800lbs with me in it. Weighs around 4100 now.
tfsbbf466
Post  rmcomprandy April 20th 2014, 8:44 pm
SO .......
What did the dyno tell you on the engine...?
Post  dfree383 April 30th 2014, 8:04 am
Bump for an update
Post  fastbarry May 4th 2014, 7:36 pm
i got busy with work and finishing the headers got put on hold.    i am nearly done with them now.  i am shooting for the dyno fri. or sat.    i am excited to see how this thing runs.
iron cj headed 460 20140504_141451
fastbarry
fastbarry
Post  bbf-falcon May 4th 2014, 10:50 pm
Very nice job on the headers. Wink
Post  fastbarry May 4th 2014, 10:53 pm
bbf-falcon wrote:Very nice job on the headers. Wink
thank you! Cool
fastbarry
fastbarry
Post  5pointslow May 6th 2014, 8:31 am
i will guess
560 hp
5pointslow
5pointslow
Post  cletus66 May 6th 2014, 5:25 pm
X2 !!!!!
