powercone spacer for dominator
dirt_worker
4speed
glenevans
I am changing my intake setup to a TFS mafia and 1150 Dominator from a track heat and 4150 carb. I did not see a "powercone" spacer listed for dominator carbs on the Jomar website. Summit has a tapered spacer from canton that looks decent. What jomar spacer would be similar to the powercone on my track heat manifold? - thanks....... Glen
glenevans- Posts : 315
Re: powercone spacer for dominator
Or maybe the question should be "what would work nicely on my 545 (I have a dominator size 1" open spacer I could try)"?
we just dyno'd an engine over the weekend with and without one and there is some power in that deal! It was a 4500 1" from Lem.-A
4speed- Posts : 127
Sweet, thanks for the info. I'll call tomorrow.
I got my jomar from lem as well. I believe he said the 1050/1150 take the same spacer.
dirt_worker- Posts : 535
I had a customer install it upside-down because it lined-up better with an un-ported "Mafia" carb pad.
He was still happy with the power result, LOL.
That is funny!!!
glenevans wrote:Sweet, thanks for the info. I'll call tomorrow.
It's on the way.....thanks.
Thank you also!
It seems that the 4500 series power cones are tough to find on jomar's site.
Here are the four styles that we stock....
5065 X that fits the 2" butterflies of the 1050/1150 carbs
5065 X1 for the 2-1/8" 1250 carbs
5065 X2 """""""" 2-1/4" 1450 carbs
5065 X3 """""""" for the 2.300" custom carb like Rob S. has.
I hope this helps......Lem
4speed wrote:we just dyno'd an engine over the weekend with and without one and there is some power in that deal! It was a 4500 1" from Lem.-A
How much is some ?
10SHOTS- Posts : 587
ha ha ....power
It made 9hp at peak hp but...what it done for the curve after peak was where I thought it really shined! Really brought those numbers up (more than 9hp)-A
4speed- Posts : 127
4speed wrote:It made 9hp at peak hp but...what it done for the curve after peak was where I thought it really shined! Really brought those numbers up (more than 9hp)-A
Thanks off the info , I have one that's been hanging on the wall in the shop for a good while I will give it a try again
It's also a great heat isolator.
Dave C.- Posts : 1268
Good observation. How well the power holds on once the engine peaks is often over looked.
Do these spacers also help average power/torque numbers below peaks?
glenevans wrote:Do these spacers also help average power/torque numbers below peaks?
Usually ... that is where the improvement will show; not necessarily at the peaks.
Thank you
I'm unsure if I have the spacer installed correctly. Should the carved area be up towards the carburetor or towards the intake. Different than any type of spacer I've ever tried.
quikmule84- Posts : 5
Taper facing away from the carb. Smooth 4 hole side to the carb.
Thanks a bunch for replying. This old racer feeling a little slow now, lol.
» Jomar Powercone
» 1050 powercone/supersucker
» Custom Jomar Powercone............
» Carb spacers??
» What spacer do u guys run with the mafi intake ,ANY?
» Carb spacers??
