Nos Jetting for 2x4's
Looking for suggestion on how to jet a 2x4 set up. Nos plates want a 175 to 200 hp set up. 605 ci alky as primary fuel. Gas for nos. thanks for any help.
Re: Nos Jetting for 2x4's
Cheater with C- 16
IIRC, you have an Alky carbs (domies) deal right, (not injected) ????
on the cheater plates this is what "Holley/NOS" shows for jetting
Table 4 Suggested Baseline Tuning Combinations for NOS Multiple-Carburetor Competition Cheater Systems
Stage
Jetting Baseline pressures Fuel Quality
N2O/Fuel N2O/Fuel Ignition Timing NGK Plug or Equivalent
100 HP 33/33 950PSI/6PSI 93 + Octane Pump gas -7
150 HP 52/52 950PSI/6PSI 100+ octane (R+M/2) * -8
175HP 59/59 950PSI/6PSI 110+ octane (R+M/2) -9
200 HP 65/65 950PSI/6PSI 110+ octane (R+M/2) * -9
250 HP 73/73 950PSI/6PSI 112+ octane (R+M/2) * -10
seems a little rich to me however these are for gasoline for carbs & enrichment...
I would check with Monty Smith @ NOS or Steve @ IS...
I can tell you that mine seemed to like a spread in the jets ( 10-12 ) & a total of 12* out of the timing (total 18*) on the smack..
(single Big shot plate)
depending on the jets you have I would try a 59n & 52f with 5.5psi on the fuel pressure...make damn sure you flow the fuel side
this is easy if you have a return style regulator like the Mallory 4309 3port deal, or get Steve's flow tool from IS.
no more than 20* total timing to start with...
Alky & C-16 have two different burn rates so plug reading is not normal!!!
get you a few sets of plugs and order some more jets from IS , you can buy individuals for pretty cheap from them , just remember your gonna need 2 of each...lol
the best advise I got was ... "take your time, ... sneak up on it" ....
Stage
Tanks that gives me a solid starting point.
Here's a link that might lend some insight on this as well. It is actually jetting info for a Cross Bar style plate fed by a single solenoid, which to a point is similar to what you have..
http://inductionsolutions.com/forums/showthread.php?1419-NOS-CrossHair-and-Cross-bar-plate-nitrous-system-tunes
These are just some general numbers and depending on your nitrous solenoid your set up will likely require even more spread to get a nice clean nitrous to fuel ratio. Just thought this still might help some of you as well.. Thanks, SJ
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
