NOS jetting
+7
dave d
Induction-Solutions
austin460
Barney
4thHorseman
11 posters
NOS jetting Empty NOS jetting
Post  4thHorseman December 14th 2009, 10:52 am
I believe there is a consensus by the quick running nitrous guys that the standard NOS jetting charts are bass ackwards - way too fat. I myself have been running a slightly leaned up standard-type tune on my ride and although I've had success so far just like most I want to run harder (and safer). I am looking for the more experienced guys to assemble a NOS/fuel/fuel pressure/timing charts for both plate & fogger to attempt to organize these tune ups. I realize that every ride is different and you have to meticulously watch plugs, ect. to get things spot on. But I think the gurus could point those of us seeking knowledge closer to enlightenment than those sloppy rich NOS charts. Thoughts?
4thHorseman
4thHorseman
NOS jetting Empty Re: NOS jetting
Post  Barney December 14th 2009, 12:06 pm
Actually Holley has changed their jetting. If you notice they have changed to much leaner baselines. for example a 225HP tuneup used to be 82n/91f ans now its 82n/76f @ 6lbs fuel and 950psi N2O.
Barney
Barney
Post  4thHorseman December 14th 2009, 1:12 pm
Really? I have yet to see this. Can you post it up here or a link?
4thHorseman
4thHorseman
Post  Barney December 14th 2009, 1:26 pm
http://www.holley.com/data/Products/Technical/A5061-1-SNOS.pdf
This is for a Big Shot plate. If you go to your specific part # it will have a instruction PDF for your kit.
Barney
Barney
Post  4thHorseman December 14th 2009, 5:43 pm
Looks good. Seems to have a 6 jet spread with the larger NOS jet and more reasonable timing adjustment. This is more in line with what I have read on the forums for their tune ups. Thanks for the heads up! study
4thHorseman
4thHorseman
Post  Barney December 14th 2009, 10:20 pm
NP, these jetting maps are alot closer than the pig fat tuneups of the past.
Barney
Barney
Post  austin460 March 31st 2013, 7:14 pm
Sorry to drag up an old thread but want to start spraying a bit. I see holley have updated for thier big shot kit, but all their smaller kits still seem to have the fat tune ups. Can anyone give a good starting point for the smaller kits and tunes i.e super powershot and sniper @100 and say 125ish. I do realise you need to watch your plugs closely but rather than starting way out I would just like to have an initial tune thats not way out.
Thanks for any help given.
austin460
austin460
Post  Induction-Solutions May 7th 2013, 3:22 pm
In many cases depending on the flow of the system around a .052 nitrous jet will flow about 100-125 HP worth of nitrous. As for a fuel jet if you start even .008 to .010 smaller at around 6 PSI you should be in the ball park.. Thanks, SJ
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
Induction-Solutions
Induction-Solutions
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
http://www.InductionSolutions.com
Post  austin460 May 12th 2013, 4:16 pm
Thanks Steve
austin460
austin460
Post  Induction-Solutions May 13th 2013, 9:40 am
austin460 wrote:Thanks Steve
No problem.. Good luck.. SJ
Steve Johnson
Induction Solutions
Shop 352-593-5900
Cell 815-341-8853
Induction-Solutions
Induction-Solutions
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  DILLIGASDAVE May 16th 2013, 7:09 am
I remember way back in ancient times when the old NOS Cheater 125, 175, 225 16 hole plate kit had a 225 jetting of 110/110, but the small passages in the nitrous solenoid were supposedly only somewhere around the .090" range.
Post  whatbumper May 16th 2013, 9:25 am
DILLIGASDAVE wrote:I remember way back in ancient times when the old NOS Cheater 125, 175, 225 16 hole plate kit had a 225 jetting of 110/110, but the small passages in the nitrous solenoid were supposedly only somewhere around the .090" range.
we've ran that tune a bunch. of course not with 6psi. we flowed the fuel volume/weight rather than pressure. now we use wide jet spreads and adjust fuel pressure to compensate. of course now having a better understanding of stoichiometry helps.
Post  dave d October 6th 2013, 8:31 pm
Question or two for the nitrous guys out there,I am running a elderbrock performer nitrous system my jets are  nos 120/120 ,plugs look good about what x-tra hp is this giving me. Shooting for a x-tra 150 hp, I will be replacing the solenoids over the winter with some bigger ones .Thanks Dave
Just looked at the nitrous booklet that came with the system it calls for 57 nos and 65 gas for a 100hp gain should I go back to a more square set up like the 65's for a better performance.
Last edited by dave d on October 6th 2013, 9:18 pm; edited 1 time in total (Reason for editing : add information)
dave d
dave d
Post  richter69 October 6th 2013, 9:42 pm
120/120? Id think that would make ashtrays
Post  dave d October 6th 2013, 9:58 pm
after looking at some other post and checking more on the system that is on the car and looking at the jets I figured that was WAY to big for my system.That is why I'm thinking more around 65's to 70's range? WANTED to make sure it was getting fuel and nitrous Laughing
dave d
dave d
Post  richter69 October 6th 2013, 10:09 pm
i ran a 75n 60 fuel with those noids and a bigshot style plate on the sb car last fall, it was around a 175 shot and rocked on that 306 deal.....
Post  dave d October 6th 2013, 10:23 pm
I've got the 65 jet and thinking of drilling out one of the smaller jets to a 70 whatever drill bit number that is and try it,this is on a elderbrock performer plate also and on a 545 pump gas motor. I have it on a 4 degree retard chip will change it to 5 or 6 degree, motor is set at 34 degree total without nitrous on
dave d
dave d
Post  richter69 October 6th 2013, 10:38 pm
buy some jets
Post  dave d October 6th 2013, 10:45 pm
looking into that also but thinking of buying a new system for winter upgrade and a few other things [ coating headers to get heat down] long winters here in ohio. NOTHING like what is happen out west. I hate FcKiNG winter:
dave d
dave d
Post  tfsbbf466 October 8th 2013, 10:39 pm
Jets are the same for most kits. Pull more timing too especially if your spraying on pump gas
tfsbbf466
Post  whatbumper October 8th 2013, 11:28 pm
tfsbbf466 wrote:Jets are the same for most kits. Pull more timing too especially if your spraying on pump gas
. There are a couple of styles of jets so be sure to get the right ones if you do decide to buy.
Post  dave d October 9th 2013, 12:42 am
Yea when I was at Norwalk this past weekend talk to so people from speed tech and they adviced me of the same thing about the jets,
guess I'll wait  to see which direction I go with this nitrous system that I'm running now. Only one more race this weekend.
dave d
dave d
Post  supervel45 January 18th 2014, 2:20 am
dave d wrote:I've got the 65 jet and thinking of drilling out one of the smaller jets to a 70 whatever drill bit number that is and try it,this is on a elderbrock performer plate also and on a 545 pump gas motor. I have it on a 4 degree retard chip will change it to 5 or 6 degree, motor is set at 34 degree total without nitrous on
        Same as above, do not drill jets. There are two major reasons, at least, NOT TO, and it most likely will bite you in athe A$$ sooner or later. Not worth it, in my view.
Post  quick 52 January 18th 2014, 6:26 pm
these are the tunes Monty gave me a cpuple ago at drag week 65n 52f 5.5fp 28* total timing.... ive sprayed that tune a lot without trouble cast piston and all
quick 52
