what is square jetting?
trying to learn alittle so explain the differents please
bigjohn2007- BBF CONTRIBUTOR
Re: what is square jetting?
square jetting is when all 4 jets in the carb are the same number...
the Coug- Posts : 3055
the Coug wrote:square jetting is when all 4 jets in the carb are the same number...thanks Coug
square jetting in nitrous is when both the fuel and nitrous jet are the same size and you run less fuel pressure.
whatbumper- Posts : 3024
thanks that two birds with one stonewhatbumper wrote:square jetting in nitrous is when both the fuel and nitrous jet are the same size and you run less fuel pressure.
whatbumper wrote:square jetting in nitrous is when both the fuel and nitrous jet are the same size and you run SLOW.
I fixed the above.. ;0 SJ
Steve Johnson
Induction Solutions
16121 Flight Path Dr.
Brooksville, Fl. 34604
Shop 352-593-5900
Cell 815-341-8853
www.InductionSolutions.com
Induction-Solutions wrote:whatbumper wrote:square jetting in nitrous is when both the fuel and nitrous jet are the same size and you run SLOW.
Now Steve, why did you have to do that. We race in a class with 5 guys running your stuff and it's great.
» Columbus All Ford Swap
» Is this an overcrushed rear seal?
» UNDER SQUARE vs OVER SQUARE
» NOS jetting
» WTB intake
» NOS jetting
» WTB intake
