Jetting-where to start at
gmsmkr
whitefield
butterbean
johndickjr
Jetting-where to start at Empty Jetting-where to start at
Post  johndickjr April 23rd 2015, 9:32 am
i have a 393w ford that is pretty decent, , i am looking for a base starting point for jets in the carb ,timing is locked out and will try it first without a power valve, here is what i have
393 ci Windsor sbf--
ross pistons
13-1 compression
cam -solid roller -.691-692 lift Duration@.050 intake 261 exhaust 268
fully ported super victor
750 mighty demon
200+cc intake runner heads
flowed 306@.650intake --246 ex
johndickjr
Jetting-where to start at Empty Re: Jetting-where to start at
Post  butterbean April 23rd 2015, 11:09 am
that 750 is toooooo smalllllllll but I would put it 80-82 square and no P/V's and see what happens
butterbean
butterbean
Post  whitefield April 23rd 2015, 11:22 am
950 cfm catogorie mid to high 80 jets !
whitefield
whitefield
Post  johndickjr April 23rd 2015, 10:39 pm
2015-04-23
butterbean wrote:that 750 is toooooo smalllllllll but I would put it 80-82 square and no P/V's and see what happens
750 demon flows more then a 850 holley
johndickjr
Post  butterbean April 23rd 2015, 11:09 pm
johndickjr wrote:2015-04-23
Really, how???? 750 CFM to a 850 CFM confused
butterbean
butterbean
Post  johndickjr April 23rd 2015, 11:19 pm
every carb maker holley-aep-etc flows their carbs dry..demon flows is wet, if it was measured dry the 750 mighty demon is close 900, here is a few post on this, and even joe sherman has confirmed this
http://www.speedtalk.com/forum/viewtopic.php?p=182595
http://www.yellowbullet.com/forum/showthread.php?t=393682
johndickjr
Post  the Coug April 24th 2015, 7:20 am
the last demon I had went strait to the junk where they belong
Post  gmsmkr April 24th 2015, 7:56 am
Well Razz Razz we have one on a stock 351w and it can't feed it enough
gmsmkr
gmsmkr
Post  noslo533 April 24th 2015, 8:22 am
I picked up 3 tenths on a well sorted combo with a qft 750 over a demon 750 back to back passes, and no tuning on the qft.. 11 to 1 347 ran 10.50s.. went from 10.83 to 10.57.. Gained 2 mph and a tenth in the 60ft 5000 stall.. I will never put a demon on anyting but a project on a budget that never goes to track
noslo533
Post  butterbean April 24th 2015, 10:02 am
same deal with me, we had a 750 demon on a 406 chebby in a 80 camaro and it went 7.42 in the 1/8th on the same day we put a 750 holley DP on it and it went 7.17 with in 1 hour of each pass so don't believe everything you read on the net!!!!!!!
butterbean
butterbean
Post  johndickjr April 24th 2015, 11:32 am
i have never had any issues with a demon,  , i had a brand new 750 Dp holley on my falcon, did ever thing under the sun to and it was never right, put the demon i have on it and was near prefect , i like them, and i have what i have, you buy me a new carb and ill use what ever you want..lol, it has to work for now till i get my new prosystem carb, either e85 or alcohol , not sure yet
johndickjr
Post  DaveMcLain April 24th 2015, 5:31 pm
noslo533 wrote:I picked up 3 tenths on a well sorted combo with a qft 750 over a demon 750 back to back passes, and no tuning on the qft.. 11 to 1 347 ran 10.50s.. went from 10.83 to 10.57.. Gained 2 mph and a tenth in the 60ft  5000 stall.. I will never put a demon on anyting but a project on a budget that never goes to track
If you picked up 3 tenths with just a carburetor swap then you didn't have a very well sorted combo.
DaveMcLain
Post  dfree383 April 24th 2015, 7:18 pm
I agree with you.... But their where a bunch of junk demon carbs built by Bg back in the day.... Everything from improperly drilled blocks to metal shavings in them. Ask me how I know.
Post  DaveMcLain May 1st 2015, 9:49 am
Tell me about it! Earlier this week I had a customer bring in a big Chevy to run on the dyno with an 871 and two Demons which needed to be rebuilt. I took them apart and went through them and while doing so I noticed that besides some awful boosters in both bodies one body had never been drilled through to allow manifold vacuum to actuate the power valve! The holes were started but not drilled through all the way. I was told that this is not uncommon on these carburetors.
DaveMcLain
Post  n5ifi May 11th 2015, 9:14 pm
If you guys looked at the specs on Demon carbs you would wonder how they ever ran properly.
Some are really screwed up.
http://www.demonfuelsystems.com/Tech/Identification.asp
n5ifi
