BBF CARB JETTING????
1Bad91
What are you guys running on these big blocks for Jetting? I'm using a 4150 carb and had 86/91 jetts but felt like my mph was falling so I went up on the jetts but mph stayed the same. My plugs seemed on the lean side when I checked them. Any info on what I should do here? I went up on the jetts to 90/95 and plugs seem a little better. I'm not sure what my limits are on jetts before I go over board with it.
1Bad91- Posts : 267
Re: BBF CARB JETTING????
1Bad91 wrote:What are you guys running on these big blocks for Jetting? I'm using a 4150 carb and had 86/91 jetts but felt like my mph was falling so I went up on the jetts but mph stayed the same. My plugs seemed on the lean side when I checked them. Any info on what I should do here? I went up on the jetts to 90/95 and plugs seem a little better. I'm not sure what my limits are on jetts before I go over board with it.
I'll say it first since I dont run a carb.
Not a 4150
Curt- Posts : 2791
I do not think a 4150 is big enough for a BBF now a Small Block yes but I feel a 4500 is the only way for a BBF
the Coug- Posts : 3055
I agree but unfortunately I dont have one right now. The car does run pretty damn good with the carb thats on it. I dont see much more out of it with a 4500. Car has been a 6.47 in 1/8 3200lb leaving at 1500rpm on street tires.
1Bad91- Posts : 267
If thats the carb you have to work with, give it what it wants, let it eat !!!
Better "to rich" than "to lean" ... get it rich and then go leaner from there.
I'm already up to 90/95 on the jetts. If I go more wont I be messing with Air bleed issues? My plugs still look ghost white. I tried square jetting it and carb did not like it. Carb stuttered alot at 92/92
1Bad91- Posts : 267
The carb have a power valve by chance in the front ??
TravisRice- BBF CONTRIBUTOR
it must not or he'd need some new plugs. what's your timing on?TravisRice wrote:The carb have a power valve by chance in the front ??
what is the carb# ?
has any port work been done to it?
do you have any vacuum leaks ??
jc10000rpm- Posts : 193
I have a 1,000 cfm Holley HP Annular Booster carb on my 466 with 86 jets in the front and 95 jets in the rear.I have a power valve in the front but not in the rear,Later Mark.
Mark Miller- Posts : 1959
I'd have to check to see if theres a power valve, but timing is on 34 degrees. There has been some small port work done to the heads too.
1Bad91- Posts : 267
The Hoilley 1,000 cfm annular carb is number 80514.
Change the high speed air bleeds to 28 or 29 from the 32's which should be in there.
Carb does have a pwr valve up front and HI air bleeds are 32's.
1Bad91- Posts : 267
rmcomprandy wrote:The Hoilley 1,000 cfm annular carb is number 80514.
How would this benefit me by switching the air bleeds down and what would I be able to do by doing this?
1Bad91- Posts : 267
For lack of writing an entire tuning manual on here ... it will richen the top end more than the bottom.
rmcomprandy wrote:For lack of writing an entire tuning manual on here ... it will richen the top end more than the bottom.
Thanks for your advice. I'm gonna try it and see what happens.
1Bad91- Posts : 267
» BT 2X4 intake/jetting front carb differently
» Jetting-where to start at
» Q16 jetting
» Nos Jetting for 2x4's
» 1050 jetting
» Q16 jetting
» 1050 jetting
