FS: Flexalite 295/298 Fans!
This is the big setup that Flexalite makes. I had this in my Cougar. I burned out control box #2 by getting it wet, and I've had it with electric fans as a result. Fans themselves work fine. Always kept my 523" Cougar under control, even on a 90 degree day cruising up a hill.
You get.
Fan setup (I trimmed one of the rubber doors)
Two brackets I used
Control box (bad, from what i can tell)
Sensor (Not pictured, gets stuck in the radiator fins)
Fuse holder + 8ga wiring (not pictured)
New it gets $460 on Summit. The fan alone (as a 298, same fan, no controller) gets $370. I'll do $275 shipped in the US, and you get the control box, which I can't figure out if it's bad or not.
Brand Flex-a-lite
Manufacturer's Part Number 295
Part Type Fans, Electric
Product Line Flex-a-lite Direct Fit Electric Fans
Summit Racing Part Number FLX-295
Maximum Fan CFM 4,600 cfm
Fan Quantity Dual
Fan Diameter (in) 13.500 in.
Height (in) 17.500 in.
Width (in) 27.500 in.
Thickness (in) 4.000 in.
Number of Blades 8 blades
Maximum Fan RPM 2,100 rpm
Blade Material Plastic
Blade Color Black
Shroud Color Black
Shroud Material Glass-reinforced nylon
Amp Draw 28.00 amps
Quantity Sold as a kit.
Notes Fits models with 28 in. wide core only. This kit includes universal mounting brackets , an adjustable thermostat (160-240 degrees), an air conditioning relay, and a variable speed control.
You get.
Two brackets I used
Brand Flex-a-lite
Fan Quantity Dual
Blade Color Black
Shroud Color Black
Amp Draw 28.00 amps
» 6.0 powerstroke fan clutch
» Flexalite dual fan
» Greetings BBF Fans
» Hi .... Ford Fans
» BBF in A Fox - Cooling Rad/Fans
» Hi .... Ford Fans
