B460 heads , intake and gaskets ,block and more
67mills
coyote runner
bbfstanger
B460 heads , intake and gaskets ,block and more Empty B460 heads , intake and gaskets ,block and more
Post  bbfstanger May 17th 2014, 10:17 pm
have eagle rods 6.535  and j/e 1.65 comp height 4.450 bore domed pistons A460 vlave reliefs makes a 528 ish? with your 4.25 crank $400
main girdle no hardware $30
alum. motor plate for a fox with a danny bee belt drive $75
wiend tunnel ram for 460 with pass car or cj type head,linkage and dual modified 660 center squirters $700
trick flow specialties A460 tunnel ram with dual dominator top $450
c6 coan 4000 stall like new $300
bigshhot nitrous kit 4150 with new plate,all jets, tank ,mainline etc. dont have relay or switches $325
pr. bob glidden drag star wheels 15x3.5  5 on 4.5 bolt pattern ,need polished up $175
will do some trading for new style tfs A460 single domi intake,
Last edited by bbfstanger on June 17th 2014, 6:44 pm; edited 4 times in total (Reason for editing : deleted sold items and put rod and piston info)
bbfstanger
B460 heads , intake and gaskets ,block and more Empty Re: B460 heads , intake and gaskets ,block and more
Post  coyote runner May 18th 2014, 3:54 pm
Still have tunnel ram
coyote runner
Post  bbfstanger May 18th 2014, 4:36 pm
which one? yes i have them both still.
bbfstanger
Post  bbfstanger May 18th 2014, 6:25 pm
n/m
bbfstanger
B460 heads , intake and gaskets ,block and more Empty pm sent
Post  67mills May 18th 2014, 6:31 pm
thx
67mills
Post  9seccomet June 9th 2014, 9:52 pm
do you still have the a460 single intake
9seccomet
9seccomet
Post  bbfstanger June 9th 2014, 10:49 pm
yes i do it has been milled some ,are your heads milled?
i dont want to sell you something you cant use.
bbfstanger
Post  9seccomet June 10th 2014, 12:07 am
no not at all when you ran this intake which thickness intake gaskets did you run .60 or .120 cause I assume you dont know how much has been milled off
9seccomet
9seccomet
Post  bbfstanger June 10th 2014, 12:38 am
bought it never used it.
i sold it to a member and he tried regular gaskets and it didnt fit i told him about the .125 gaskets but i dont think he tried them.
i took it back, id give you the same deal 200+ ship and if it doesnt fit send it back and ill give you the 200 back.
at worst you would be out shipping both ways.
bbfstanger
Post  J.Toney June 10th 2014, 11:52 am
Pic of the A460 TR?
J.Toney
J.Toney
Post  9seccomet June 10th 2014, 12:03 pm
Did he say what didn't work about the intake was it China wall gap
9seccomet
9seccomet
Post  bbfstanger June 10th 2014, 1:00 pm
it set low on the ports,needed thicker gasket to raise it up.
bbfstanger
Post  bbfstanger June 10th 2014, 1:02 pm
pic of tunnel ram
B460 heads , intake and gaskets ,block and more DSCN0276
bbfstanger
Post  bbfstanger June 11th 2014, 8:26 pm
fms single A460 intake sale pending.
bbfstanger
B460 heads , intake and gaskets ,block and more Empty Tunnel Ram
Post  747JetMech June 17th 2014, 12:35 pm
Are there different versions of your TF Tunnel Ram?
Thx
Tom
747JetMech
747JetMech
Post  bbfstanger June 17th 2014, 1:21 pm
yes they made a couple versions,mine is an older one with the bbf water neck ,later ones used a sbf neck,they all work good!
bbfstanger
Post  Lt1 September 9th 2014, 9:58 pm
Do you still have the trick flow tunnel ram? If so pm
Lt1
Lt1
