Intake gaskets for DOVE-C heads
Does anyone know what felpro gasket number I should use on a set of DOVE-C heads with a 4150 flange Edelbrock Victor manifold?
I got P.N. 1420, and the port openings are huge! Way too big to even try and port match to gaskets on either the manifold or the heads.
Thanks in advance
Thanks in advance
Vermaverick- Posts : 35
Re: Intake gaskets for DOVE-C heads
Vermaverick wrote:Does anyone know what felpro gasket number I should use on a set of DOVE-C heads with a 4150 flange Edelbrock Victor manifold?
Thanks in advance
There is none. What you need is usually called a "Victor port match".
The HEADS will need to be port matched to the intake and it will not match exactly when finished. Those giant CJ intake port gaskets must be used to have a good seal all the way around. Under any circumstances, do not match either ports to the gasket.
Thanks rmcomprandy,
I was shocked when I laid the gaskets up to the heads.
So I do actually have the right gaskets, just don't try to open the ports on the heads or on the intake to try and match the gaskets right?
What ford heads actually have the ports that do fit those giant holes?
Vermaverick wrote:Thanks rmcomprandy,
Correct.
Cobra Jet heads -- D0OE-R
Make a thick paper template from the manifold and use it as a guide for port matching the cylinder heads.
» Intake gaskets for Thor Gen 1 heads?
» the dove c heads i bought , i measured the intake valves they were 2.250 assuming these are not stock valves ?
» A429 Heads VS Dove-c Heads
» Best 460 cj intake gaskets
