10" converter??? 9.5"?
Moodyblues
What size converter is suggested for a glide - BBF? I have a 1.76 glide with turbo shaft. 572 BBF/1000 hp. Ive been running a 8" 5500 stall for a 499 ford that ran 5.40s in a chassis car about 800 hp.
Re: 10" converter??? 9.5"?
FTI # SSW-93B would work like a charm. I had one behind my 598. Little more power than yours and it was just a touch loose. Yours would be dead on. I now run a SSW-93BC. The C added on the end is a different fin angle and it's about 350 rpm tighter. Loose is good in an all motor lightweight car like yours.
http://fticonverters.com/
It's a 9"
http://shop.fticonverters.com/SSW-Winner-Series-Racing-Converters_c86.htm
pm me if you get a chance
It's a 9"
Toyota core ftw......
and I'd change that gearset if its a helical gear.
Thanks fellas I talked to Troy and he can fix me up. Enjoyed the conversation David
I have a new Fti ssw93b with Less than 20 passes I'd sell
10SHOTS- Posts : 587
it was set for motor , this is a old post , converter is long gone
Moodyblues wrote:What size converter is suggested for a glide - BBF? I have a 1.76 glide with turbo shaft. 572 BBF/1000 hp. Ive been running a 8" 5500 stall for a 499 ford that ran 5.40s in a chassis car about 800 hp.
Have you given Lenny a call @ UCC ... he could probably help and guide you in the right direction
Thanks for the response , no , I haven't talked to Lenny yet, may have to give him a call , thanks again !
» New Ultimate Converter Concepts Converter Test Results-Updated
» NOS converter
» Early 429 crank pilot diameter
» C6 leaking out of bellhousing-All back together and its still leaking!!!
» C4 converter
» NOS converter
» C4 converter
