C6 leaking out of bellhousing-All back together and its still leaking!!!
+7
Dave C.
Gregaust
aquartlow
512Fairlane
11 posters
I developed a small trans. fluid leak last season out of my bell housing. I'm pulling the trans out tomorrow and was wondering what to look for. Is it most likely the seal around the converter or should I take the pump out and replace that gasket as well? Can I change the seal without removing the pump?
512Fairlane- Posts : 694
Re: C6 leaking out of bellhousing-All back together and its still leaking!!!
Yes the seal can be changed without taking the pump out on Ford's or everyone I have had could be changed by pulling the converter then pop the seal out and bump the new one in.
http://image.fourwheeler.com/f/8681507+w600+cr1/p120651_image_large.jpg
I have heard the servo lever pin needs sealant, others here are much more versed on what is needed to be looked at though.
aquartlow- Posts : 169
I took the trans out today and I'm having a difficult time telling where the leak is coming from. The seal in the center looks fine and there wasn't any fluid on the converter or coming out of the center seal area. The only place that it is wet is at the bottom of the pump where the o-ring seal is located. It seems like it would be hard for it to leak there but since the trans is so difficult to remove I want fix any possible areas while I have it out. Can I just pull the pump out the front or do I have to take the valve body out first? Will it go right back in or is there something that I need to line up inside?
You could pull the pump. Nip up the band though to make sure the drums stay put. Good idea though to remove the valvebody and check endfloat before and after so you know it's all gone back in ok .
Gregaust- Posts : 625
Ok I changed the pump gasket, O-ring and seal, put it all back together during many late nights this week. I fired it up and everything sounded good. Ran it for 5 minutes and shut it off. 5 minutes later there is a 4" diameter puddle coming out the inspection cover on the bellhousing. I was very careful with the seals. When I took it apart it hadn't been driven for a couple of months so I couldn't tell where it had been leaking from. I changed the seals and filled that little hole with RTV to be sure. Could my converter or pump be cracked? I inspected it really well when I had it out and didn't see anything. Is there a way to bench test this? If I take it to my trans guy can he pressurize it to see where it leaks. Very pissed right now. Why do we race again?
Why do we race again?? Because we love it...and if we didn't have hassles, we wouldn't be racing. If it was easy and cheap, EVERYBODY would be racing.
You'll beat this thing. Just take a step back and a deep breath. If the C6 guys on this board can't help you out, this would be a perfect time to go 'glide.
maverick- BBF CONTRIBUTOR
Is the leak worse now ?
Dave C.- Posts : 1268
did you seal the upper bolt hole on the drivers side bellhousing? remember it is drilled thru to the lifter valley.... and can and will leak if not addressed....
the Coug- Posts : 3055
Dave it is leaking worse. Coug it is leaking trans fluid not oil. I have to take it to gateway next weekend to have the chassis inspected so it will have to stay together for another week.
most likely the converter is leaking on a weld , take it some were to get pressure checked
Frank Merkl- Posts : 1524
you could get a bottle of trans fluid dye from Napa and a black light to trace the leak before you took it back out . I have experienced a cracked weld on a converter before .
maverick532- Posts : 181
Frank Merkl wrote:most likely the converter is leaking on a weld , take it some were to get pressure checked
that's what I was going to say. This happens sometimes. also if it's not a billet backing plate they sometimes separate the ears from the converter a little.
whatbumper- Posts : 3024
The 2009 sd trucks, whoever welds the hubs on the converters well they need a diff job.... Happens a lot.
Yep its the converter.
Got the converter out and pressure tested it. Its leaking around the pilot hub that goes into the crank when you apply pressure. Guess I'll give Lenny a call tomorrow and see how fast he can fix me up. First race in a few weeks.
