leaking fluid?
leaking fluid?
I just got around to starting my engine with new C4 trans and converter and I have fluid running out of bellhousing looks like behind converter. All new seal kit and drums built by jay as well as converter. Would sound like faulty seal but other than that what else could it be? Pump clearance was set at .10-152ft.
stanggt- Posts : 494
Re: leaking fluid?
stanggt wrote:I just got around to starting my engine with new C4 trans and converter and I have fluid running out of bellhousing looks like behind converter. All new seal kit and drums built by jay as well as converter. Would sound like faulty seal but other than that what else could it be? Pump clearance was set at .10-152ft.
Sound like the front seal may have got tore when the convertor was put in or might have the wrong seal
Re: leaking fluid?
Hopefully its obvious when I pull trans back out.
Re: leaking fluid?
It was obvious lol. Put c6 bushing in but not front seal. That fixed it!
» C6 leaking out of bellhousing-All back together and its still leaking!!!
» C4 leaking
» C6 leaking....
» C&C block leaking
» Nut on reverse brake band adjuster leaking - C6 transmission
» C4 leaking
» C6 leaking....
» C&C block leaking
