DB Electrical starters on larger engines?
+9
D. Sea
13 posters
Has anyone used the DB Electrical starters on larger engines with good results? Lot of threads about them, with mostly good reports. However, the majority of them were reported as being used on 466, 472, perhaps a 514 ci engine. How about any used on a 14:1 598ci deal?
These are the pmgr type mini starters. This one:
http://www.dbelectrical.com/p-1324-new-ford-mini-starter-truck-van-mercury-460-engine-3226-sfd0030.aspx
I recently broke the planetary in my CVR Denso style starter. It's been a good one. 12 yrs old on 557-588-598 alky injected combos. Doesn't owe me anything. I got it fixed at a local starter shop for $95 and put it back on. I got to thinking I need a spare in the trailer, so on a whim I ordered a DB Electrical unit. It might not handle it, but I figured it would be worth a shot at the price.
Got it it, it looks decent enough. Tested it with jumper cables and then drilled the threads out of the upper bolt hole since I use an Ultra Bell. Back in the box and into the trailer.
Edit: I found why I got the kickback that broke the planetary on the CVR starter. Low Voltage. The nut on the Ford style solenoid (down low on my fire wall) that held the battery cable on had loosened up. Found where it was so loose it had been arcing. Cleaned up and tight now.
Re: DB Electrical starters on larger engines?
David Cole wrote:Has anyone used the DB Electrical starters on larger engines with good results? Lot of threads about them, with mostly good reports. However, the majority of them were reported as being used on 466, 472, perhaps a 514 ci engine. How about any used on a 14:1 598ci deal?
I ran one on my 552 14.7 c/r it had a broke ear on top my bottom bolt on my c6 striped out and let the starter get loose put a wash and bolt all the way thro trans and Helicoil tread in the bottom work good until the battery was low and it kicked back and finished the ear off. I put a mini hi tq starter back on I bought for a back up. But I had great service out of it other my mistake with the bolts going to get one to have as a back when and if the mini goes out.
If the DB units have as much tq. as the production 460 Ford mini starters they'll do your 598" just fine.
David,
I used to run one and I have one on Dads Nova. Good starters however I broke the one in my car with the 534ci. Been running a truck starter ever since and IMO the truck starter works much better and I can now remove the starter without removing any header tubes. Plus the exact same starter is on my tow truck AND I have a lifetime warranty on the starter via O'Reilly.
Get the truck starter IMO.
D. Sea- Posts : 2768
15.3:1 580 inch on 16 volt battery and it sounds like it has no spark plugs in it when its cranking.
great starters for the price ! they just don't like kick backs ! but none due ! there all I use as there $30 cheaper that I can find them here
Frank Merkl- Posts : 1524
My 557 14.1 twirls great w/just 1 12v battery. Easier to install than a stock (big) Ford starter. I bought 2 for less than $100,and he sent both @ free shipping.
I got one for a spare and it wouldn't fit because of the oil pan.
IDT-572 wrote:15.3:1 580 inch on 16 volt battery and it sounds like it has no spark plugs in it when its cranking.
16v is the tits.
2 motorcraft 850's parallel with 00 welding lead for power and ground FTW...!!!!
torino501- Posts : 417
That's why I like the summit mini starter with its 18 positionscool40 wrote:I got one for a spare and it wouldn't fit because of the oil pan.
nuclearcobra- BBF CONTRIBUTOR
I liked the little DB starter's size, power and price, but after a couple of weeks being installed the starter wouldn't fully engage my flywheel causing it to grind. I sent the 1st one back and DB took care of it, quickly(GREAT customer service). I installed the new starter and after a few weeks the same thing, starter grinding, so I returned it for replacement. Frustrated/concerned about maybe having a flywheel issue, I picked up and installed a used '96 F350 w/460 auto starter from a U-pull-it yard and haven't had a problem since and that has been 4 months ago. I now have my 3rd brand new DB 460 starter that resides on my shelf if I ever need it. I don't use my vehicle all the time, I only put about 5K a year on it, so it may or may not get more use than others here that use the DB starter. It sucks when you are at a cruise-in or wherever and you attempt a start and it grinds(loudly), reminds me of a badly shimmed GM starter. DB's customer service is excellent, though the performance/longevity of their starter falls short(at least in my experience). Good luck. Todd
aquartlow- Posts : 169
D. Sea wrote:David,
X2. Use the '96 Ford truck deal...and get a lifetime warranty on a RACECAR part for a change.
maverick- BBF CONTRIBUTOR
