Meziere water pump question
Larry T
i am concerned that the water flow may not be correct.the meziere water pump is wired correct and runs just fine im just not sure the flow through the water system is correct.i have a gm style radiator bottom outlet is on the passenger side and top outlet is on the drivers side.
will the radiator flow water either way? the pump turns clockwise should is turn counter clockwise for the gm radiator?
Larry T- Posts : 1076
Re: Meziere water pump question
Wont make any difference.....water goes in the top of the radiator and out the bottom.....
ok I was just concerned that radiator was cold and the temp gauge showed 130ish but I didn have it started for very long maybe 3 min.
Should see flow when you take the rad cap off after therm opens.
bbf-falcon wrote:Should see flow when you take the rad cap off after therm opens.
Electric water pump + thermostat = bad
D. Sea- Posts : 2768
I was checking to see with my cap off how good water was circulation and it hardly moving but the car stay cool.Well, let me say like this when the car start to heat up I can turn on the water pump and fan and I will see it drop.I have my pump and fan wired together could the volt be lower causing it no move the water?
bigjohn2007- BBF CONTRIBUTOR
If it stays cool, be happy.
If it was mine. the pump and fan would be on separate relays.
maverick- BBF CONTRIBUTOR
D. Sea wrote:bbf-falcon wrote:Should see flow when you take the rad cap off after therm opens.
in place of the thermostat I have a piece of sheet metal with a 3/4 hole seems to work.i took a look at the water movement today.when I turn the pump on water level drops about 1in and I can see movement so everything is kosher.
Now take out the 3/4" restrictor and you'll be good to go.
CDMBill- Posts : 182
» Meziere Water Pump - New in the box
» Water pump question
» elecrtic water pump question
» Relation of mech. water pump to Meziere
» Water Pump - Pulley Configurations question
