found a motor forsale ... does this sound right ?
+6
bbfstanger
lghting94
kjett
5pointslow
10 posters
found a motor forsale ... does this sound right ?  Empty found a motor forsale ... does this sound right ?
Post  5pointslow May 28th 2014, 6:55 am
found a motor fresh ready to run , for 1300 $
its a 488 he says
stock crank , cobra jet rods with arp hardware , arias pistons (.120 or .125 over ) he says
solid lifter cam , viktor intake, D3 heads little bowl work he said
last year went 10.30s in a 2800lb car he said , went with a bigger motor
Im interested in this to use right off the bvat to get in the car and get shaked down and more or less get used to the car .
Only thing is .120 or .125 over sounds like a lot
5pointslow
5pointslow
found a motor forsale ... does this sound right ?  Empty Re: found a motor forsale ... does this sound right ?
Post  kjett May 28th 2014, 7:28 am
Don't think a stock block can go that far. I have a 488ci and it took going .060 on the block, offset grinding the crank to 3.975 and a set of Chrysler rods. It's an old school puller setup. Sounds like that motor is off a little bit  Shocked
kjett
kjett
Post  5pointslow May 28th 2014, 7:34 am
yeah im kinda on the fence , the thing is i know the car seen it run . i know its runs that # just i thought it was a mildly built 460 or 466,472 deal ........ when he said 488 i was wondering how
5pointslow
5pointslow
Post  lghting94 May 28th 2014, 8:18 am
There are some factory blocks that will go to 4.500 bore(.140 over stock) just have to be sonic checked before you do it.
lghting94
lghting94
Post  cool40 May 28th 2014, 9:18 am
If you dont check one it'll definitely go 4.5"bore!  Rolling Eyes that $$ dont buy much nowdays so........
Post  5pointslow May 31st 2014, 10:01 pm
picking this up next weekend , heads are actually c9ve heads similar to the dove heads i believe .
5pointslow
5pointslow
Post  bbf-falcon June 1st 2014, 10:25 am
Watch out.
Post  bbfstanger June 1st 2014, 10:56 am
.125 over is alot,did he have any paperwork for the engine like the sonic test papers?
i had 8 diff. year blocks checked, all of them would take an .080 overbore , one C9 woulda gone .110.
one block a dove block will go .140 over.
friend of mine had a dove block that was thin at .030
its hit or miss on a thick one.
now that being said if its been running for awhile ,you've seen it run the number and its cheap enough id say go for it.
it sounds like maybe he dont remember exactly whats in it?
bbfstanger
Post  5pointslow June 1st 2014, 8:17 pm
it has been ran last year , seen the slips and cat run .
was a bracket motor and was sonic checked , its a gamble but getting its for 1k ...is freshly re ringed and new bearings . Cant buy to much at 1,000$
motor is half filled as well .
5pointslow
5pointslow
Post  5pointslow June 2nd 2014, 9:27 am
its a gamble
bore 4.480 ...... its a .120 over to be exact hard to throw together somthing for that money .....but make me re-think a little .
im looking at it to get somthing to get car moving and shooken down before building somthing . But in long run not sure if this is the best bet with this bore size
block is a c9 ...said it was sonic checked when machined years ago , but no paper work . IT has been racing the past year though
5pointslow
5pointslow
Post  dfree383 June 2nd 2014, 9:36 am
For a grand.... It's a good throw away after you run it a bit.
Post  5pointslow June 2nd 2014, 9:47 am
arias pistons
stock crank
solid lifter cam
weihand stealth intake
not sure of compression but he said it between 12.1-13.1
with an 850 on the stealth intake it went 10.30s all day ....... i would think a viktor with a 1050 it pick up ?
I have also heard the stealth intakes are not terrible up 6500 rpm
5pointslow
5pointslow
Post  5pointslow June 2nd 2014, 9:59 am
im on the fence ......
my old man keeps telling me a $1000 isnt bad but when it cracks a cylinder and wets the rear tires .....how is that $1000 now  Shocked
i told him he has a point
5pointslow
5pointslow
Post  Paul Kane June 2nd 2014, 11:48 am
Sounds like a combo from a long time ago, not necessarily a bad thing. In my opinion a freshened, ready-to-run 488 with forged pistons, ported C9VE heads, etc, could be a great deal at $1000, and since it's got a half-fill (presumably to the waterpump holes) I don't think the overbore is an issue at all.  The actual value of the engine is in its details, but if it has good port work, stainless valves, proper camshaft for the combo, etc, and just received new rings and bearings then $1000 is a bargain. I'd still take it apart after purchase and inspect prior to running but this is true with any second-hand engine I'd consider buying.
Any given cylinder block can be safely overbored much further after it's been filled. A hard-blocked engine can still have its cylinder walls sonic checked, but what's the point in this case as you've seen the car run.
Post  Curt June 2nd 2014, 12:21 pm
I've had a couple of .120" overs. I broke the reground cast cranks long before I had cylinder problems.
Post  5pointslow June 2nd 2014, 12:43 pm
surprised it went as good as it did with the dual plane stealth on it .....seeing the car run and then seeing the intake ....just would have thought to have seen a viktor on there . if it works dont fix it i guess
5pointslow
5pointslow
Post  Ammosteve June 18th 2014, 9:01 am
What did you decide?
Ammosteve
