solid roller lifter recommendation
+8
CHARLIEB
kim
fordguy69
CDMBill
68galaxie
dirt_worker
12 posters
solid roller lifter recommendation Empty solid roller lifter recommendation
Post  dirt_worker May 28th 2014, 11:39 pm
I think im gonna upgrade the lifters in my 557...currently have the comp rollers.
Considering Morels or Isky red zones.
What would you guys recommend. This thing is gonna see some street miles and strip time.
dirt_worker
dirt_worker
solid roller lifter recommendation Empty Re: solid roller lifter recommendation
Post  cool40 May 29th 2014, 2:46 pm
I like Crower but on the street.........not a good idea Imo.
Post  Lem Evans May 29th 2014, 2:49 pm
Gotta be careful with the spring pressure on street driven engines.
Post  dirt_worker May 29th 2014, 3:53 pm
If this thing sees 500-1000 miles per year Id be surprised.
Since you asked though I've got the manley Nextec Springs.
dirt_worker
dirt_worker
Post  Lem Evans May 29th 2014, 4:40 pm
Which ones ? They can be 600,800 or 1,200 open.
Post  dirt_worker May 29th 2014, 9:03 pm
I cant remember...I can say that theyre the springs tfs installed on my A heads.
dirt_worker
dirt_worker
Post  dirt_worker May 30th 2014, 11:45 pm
Anybody?
dirt_worker
dirt_worker
Post  68galaxie May 31st 2014, 10:25 am
I think Manley Nextek #221424 springs are sold with TFS A heads. Someone could confirm this.
250lbs @2.00" and 800lbs @ 1.15"
Crower has the bushing type solid roller (as several others do now).
The regular HIPPO solid roller lifters can be rebuilt by Crower to the bushing configuration ( I have heard)
The next time I need a lifter refresh, I will probably send them for the bushing re-build.
68galaxie
68galaxie
Post  CDMBill June 3rd 2014, 11:38 pm
I have had very good durability with the Isky Red Zones Stage 2 bushing style rollers. Came out looking good after two years, two Drag Weeks, multiple True Street and other events and about 8,000 street miles. Sent for check out rebuild, but they really didn't need it.
Valve springs are Isky Tool Room 230 on the seat 720 open at .830 lift. TFS A460 version 3 heads with Lem's CNC porting and 2.40 TI intakes, 1.88 SS exhaust.
CDMBill
Post  dirt_worker June 4th 2014, 12:12 am
Thanks Bill.... I lost these guys when I said street Sad
I suppose you know a thing or two about that. Lol
I had 900hp...gonna be dynoing again soon and hoping for 4 digit hp.
Btw Bill...how ofter do you have to replace valve springs?
dirt_worker
dirt_worker
Post  CDMBill June 4th 2014, 7:08 pm
Good question. I stretched the change interval after 2011 - 2012 season and broke a spring on the intake side. Big mess as you'll imagine as it happened during a run at the Pomona NMCA race.
So with the bigger cam I'm going to, .900 lift, I expect to be at annual changes. To be safe. I was checking seat pressure regularly and didn't see a chnage but they fatigue. I am adding spring oilers this time as well. We are looking for something closer to 1050 this time with 10 more cubes and the cam change. We made 1019 last time.
CDMBill
Post  fordguy69 June 4th 2014, 7:29 pm
Bill, I think it was Chris Straub that mentioned the bushings don't like dirty oil. The recommendation was 1000 mile oil change intervals. Did you follow that?
fordguy69
Post  kim June 4th 2014, 7:53 pm
fordguy69 wrote:Bill, I think it was Chris Straub that mentioned the bushings don't like dirty oil.  The recommendation was 1000 mile oil change intervals.  Did you follow that?
That would be about 8 years before the car see's 1000 miles.
kim
Post  fordguy69 June 4th 2014, 9:04 pm
He said in his earlier post 2 yrs and 8000 miles??
fordguy69
Post  CDMBill June 8th 2014, 10:30 pm
I don't change the oil quite that often. As soon as it gets cloudy is my change interval. The oiling system holds 9.5 quarts total so that may extend it a bit. I'd guess it varys between 1000 to as much as 2000 miles. The EFI seems to keep the oil cleaner longer than back with the carb.
CDMBill
Post  CHARLIEB June 9th 2014, 12:07 am
This is a good topic :
I have anybody heard or used Comp Cams Sportsman Solid Roller Lifters 96838B-16. The ones I listed with part number come with Bronze bushing axle. Comp Cam offers two version of the Sportsman lifters in Bronze bushing or Needle Bearing Axle.
Right now I have the Comp Cams Endure-X Roller Lifters 836-16 but was thinking about sending them back for the Sportsman with Bronze bushing.
Any though or comment on these lifters?
CHARLIEB
CHARLIEB
Post  CDMBill June 9th 2014, 8:22 pm
I haven't used those particular lifters so I can't comment on them. My reason for changing from the needle bearing lifters to bushing style was two different failure events one which may not have started at the lifter and one that definitely did, but the result was the same, needle bits all over the place, particularly on the upper side of the piston skirt whoch resulted in an over bore and new pistons each time.
Eventually stuff will break, and while I haven't lost a bushing lifter yet, my thinking is that even if it seizes or something similar it will do less damage than the needles.
The sound you hear is me knocking wood.
CDMBill
Post  dirt_worker June 11th 2014, 11:37 pm
I ordered the Crower bearingless lifters today...
Cheap insurance imo Smile
dirt_worker
dirt_worker
Post  CHARLIEB June 12th 2014, 10:02 pm
CDMBill wrote:I haven't used those particular lifters so I can't comment on them. My reason for changing from the needle bearing lifters to bushing style was two different failure events one which may not have started at the lifter and one that definitely did, but the result was the same, needle bits all over the place, particularly on the upper side of the piston skirt whoch resulted in an over bore and new pistons each time.
Hello bill, I think I'm going to exchange the comp cams 836-16 for the ones that are a step above the ones I have listed. My builder said the ones I have now will work wirh the cam profile he will spec out and I will be able to drive it on the street and be durable. I 'm not going to take that chance and have needles everywhere in the motor. I'm going to spend the extra money to be on the safe side.
CHARLIEB
CHARLIEB
Post  CHARLIEB June 12th 2014, 10:05 pm
dirt_worker wrote: I ordered the Crower bearingless lifters today...
I hope your lifters serv you well with your build.
CHARLIEB
CHARLIEB
Post  dirt_worker June 14th 2014, 11:47 am
Wow..these bushed Crowers are nice!
dirt_worker
dirt_worker
Post  norm June 14th 2014, 11:18 pm
Do yours have the groove from the oil band to the oil hole already? I had to put a small groove on mine and have seen some that were grooved from the factory.
norm
norm
Post  tfsbbf466 June 15th 2014, 2:38 pm
Are all if these bushing-less lifters still $1000 plus? If I ever go back to a roller again this is my one and only choice. I'll never run a needle bearing solid lifter again.
tfsbbf466
Post  dirt_worker June 15th 2014, 6:06 pm
Yup...........but $1000 is cheap compared to the damage caused by a failed needle bearing.
dirt_worker
dirt_worker
Post  dirt_worker June 20th 2014, 9:32 am
Comp lifters on the left..crowers on the right.solid roller lifter recommendation 20140617_194009_zpsnlpyj7ns
dirt_worker
dirt_worker
