Need a roller lifter and rocker recommendation
+8
lvhdude
56Tbird
psfracer
Wheelie58
BLACKFOX
12 posters
Need a roller lifter and rocker recommendation Empty Need a roller lifter and rocker recommendation
Post  BLACKFOX January 25th 2013, 12:17 pm
I'm looking to replace my roller lifters and rockers as they are pretty old. The car is an 89 mustang. The engine is a 12:1 521 with out of the box P-51's. The cam is a Comp with .742, .745 and 255, 264 @.050. The engine also sees a lot of street driving at lower rpm so oiling to the axle is a concern. I usually shift around 7000-7200.
BLACKFOX
Need a roller lifter and rocker recommendation Empty Re: Need a roller lifter and rocker recommendation
Post  Wheelie58 January 25th 2013, 2:58 pm
If you are running the OE .874" diameter lifter you have several great choices.
I have had good results with Crower lifters. They offer oiling options as well as the needle-less Enduramax design. You may want to call them and discuss your application.
Keith
Wheelie58
Wheelie58
Post  psfracer January 25th 2013, 3:34 pm
I have had no issues at all with my Crower lifters. My comp cam is similar in lift but I have more duration. The T&D shaft mount rockers have been awesome so far also. I have checked my valve lash several times over the last year and they just don't come out of adjustment. I also have P51s.
psfracer
psfracer
http://www.psfracer.com
Post  the Coug January 25th 2013, 4:04 pm
I have used crane, comps, Lunati, and Crowers I like the crowers better for the oil grove neck is beefier than the others and under some instances I have seen some tweaking on the necks, not that noticeable but some for sure....
Post  56Tbird January 25th 2013, 8:49 pm
the Coug wrote:I have used crane, comps, Lunati, and Crowers I like the crowers better fore the oil grove neck is beefier than the others and under some instances I have seen some tweaking on the necks, not that noticeable but some for sure....
fore has no "e" in this use.......where in the hell did you learn to spell??? You need spell check Razz
56Tbird
56Tbird
Post  cool40 January 26th 2013, 10:31 pm
crower for me. last set i got a good deal from Kaase. Very Happy
Post  richter69 January 26th 2013, 11:54 pm
MOREL AND CROWER
Post  lvhdude January 27th 2013, 3:05 am
Just curious but how many miles would you say you have on your lifters? I'm wondering about rollers for street use. Thanks!
lvhdude
Post  BLACKFOX January 30th 2013, 11:25 am
They probably have 700-800 street miles on them. There isn't anything "wrong" with them they're just old and technoligy has gotten better so I thought I'd upgrade while I had the engine apart this go round.
BLACKFOX
Post  dfree383 January 30th 2013, 12:29 pm
I like the Comp Elite lifters and the new pro magnum rockers
Post  CP598 February 2nd 2013, 1:57 pm
As Keith said, there are several good choices. I have 3 seasons on the Isky Redzone's, and all is well, this isn't a street application though. Have been using the Crower Stainless rockers for about 10 seasons with no issues as well.
CP598
CP598
Post  schmitty February 2nd 2013, 2:20 pm
The Crower SS rockers are about the best non shaft rockers money can buy. You can put them in the will for your kids. Cool
Comp Elite lifters are darn good stuff, but they aren't cheap.
Post  460Dave February 16th 2013, 11:13 pm
Howard's rockers here... not sure how their strength compares to others. They appear to be a quality piece. I haven't had any problems with them.... But they sure look cool (purple anodized)
460Dave
