Header bolts
Header bolts
What are you guys using for header bolts? I have 2 1/8 primaries and was wondering what you're having the best results with
Mike R- Posts : 1381
Re: Header bolts
I'm one of the lucky ones that can run allen headed set screw (studs) w/lock washers and nuts.
Re: Header bolts
Usta run allen head capscrews, but went to studs and 12 point nuts last year. Waaay easier to get the headers hung.
JACKAZZFLATZ- Posts : 249
Re: Header bolts
JACKAZZFLATZ wrote:Usta run allen head capscrews, but went to studs and 12 point nuts last year. Waaay easier to get the headers hung.
I agree 100%
crittersf1- Posts : 521
Re: Header bolts
Thanks guys I'm on my way to the hardware store
Re: Header bolts
I have had good luck with some made by "Percy's", and there may be others who make something similar. They have a 12 point head with a small allen set screw in the center. Tighten the bolts and tighten the set screws and they don't come loose.
TJ
TJ
Tommyj466- Posts : 322
» Forged pistons NIB, ARP rod bolts, SCE header gaskets
» arp rod bolt needed
» arp rod bolts?
» Eagle h-beam 6.8 rods
» eagle rods in 545
» arp rod bolts?
» eagle rods in 545
