ROLLER LIFTERS FOR C HEADS
procharger 528
hi i'm looking at getting some new roller lifters for my C 460 headed engine,
i have looked at comp cam endure x lifters 879, crane 35571r and crower 6637h,
I'm a little confused,the crower ones are looking good but im not sure,
i have had a lifter failure and i want to get something better i had comp lifters in it before,
the cam lift is 904 and is a Pro charged 572 drag engine any help would be appreciated and the best place to buy from?
i'm also after valves as well ....thanks
procharger 528- Posts : 45
Re: ROLLER LIFTERS FOR C HEADS
Look at Morel and Isky lifters too.
I'm assuming you looking for titanium valves?
the crane 35571R-16 are morels
Frank Merkl- Posts : 1524
Are you sure about that? The on center .875" Crane ultra pro lifters are darn sure not Morel.
I have the comp cams endure-x. They seem to be good so far... one season on them..
Had to grind them pretty hard to clear my 3/8 pushrods even with the offset cups..
I like the body design for sure.. Probably be looking at a set of bushed ones next time tho..
dkp
dkp
bosshoss- BBF CONTRIBUTOR
Lem , my son said they look like they are , when the 600 comes out I'll take a pic and post it
does anyone have a a part number for morel roller lifters?
yes titanium valve thanks
Morel part #'s
http://johncalliesinc.com/morel_products.php
Just noticed they have now added a bushing lifter to their shelf stock part #'s in both .875 and .903 sizes in both std and offset.
I have the 5456 in my A head deal (no offset needed)
pics of the crane lifters
Not morel. They do look a lot alike. Notice the machined groove to the oil fed hole....lets oil get to the push rods.....Morels do do have that.
I have a set of used titanium valves i would sell reasonable if you are interested pm me . Victory 2.45 and 1.80 coated. About 225 1/8 mile passes on them .
KY JELLY- Posts : 1530
» Heads off to change solid roller lifters?
» Using Hydraulic roller lifters on the Comp XR292 R-10 Xtreme Energy Solid Roller cam?
» C460 Pistons+roller lifters and roller cams...
» Roller Lifter Question
» hydraulic roller cam with solid roller lifters
