Heads off to change solid roller lifters?
Heads off to change solid roller lifters? Empty Heads off to change solid roller lifters?
Post  fat64 February 16th 2019, 11:06 pm
Looks like I have a lifter or two going away. Anyone happen to know if I have to remove the A-429 heads to swap roller lifters?
fat64
Heads off to change solid roller lifters? Empty Re: Heads off to change solid roller lifters?
Post  BOSS 429 February 16th 2019, 11:24 pm
fat64 wrote:Looks like I have a lifter or two going away. Anyone happen to know if I have to remove the A-429 heads to swap roller lifters?
3
On a bbf you should not have to, just remove the intake
Post  Mark Miller February 17th 2019, 12:55 am
3
X2,I have the Comp Solid Roller lifters in my 466 with the Aluminum A-429 Heads and the lifters come out with just taking the Intake off and not the heads!!Smile
Post  68galaxie February 17th 2019, 2:45 pm
I did not have to pull heads to change roller lifters on mine.
Using Crower HIPPO lifters.
Cheers
68galaxie
68galaxie
Post  fat64 February 17th 2019, 3:37 pm
Huge thanks for the replies guys. Glad it wont be a huge job now. Relacing with another set of Comp solid roller Endure-x lifters.
fat64
Post  rmcomprandy February 17th 2019, 9:21 pm
fat64 wrote:Huge thanks for the replies guys. Glad it wont be a huge job now. Relacing with another set of Comp solid roller Endure-x lifters.
Comp Cams has a rebuild policy for those lifters.
Post  fat64 February 17th 2019, 11:23 pm
Don't know if that will work from here in Australia. Probably just about cheaper and quicker to pick up a new set.
fat64
Post  rmcomprandy February 18th 2019, 11:34 am
Including shipping costs ... you are probably correct.
Post  fat64 February 18th 2019, 4:16 pm
Just looking for the part number and I see there are 3 different types of Endure-x roller lifters for this engine. I'm not sure what's in there.
Can anyone tell me what the difference is and which ones I need? I'm running T&D rockers if that makes any difference.
fat64
